Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 09-14-2007, 02:38 PM
david_geng is on a distinguished road
0.017mm backlash
hi, I measured 0.017mm backlash on the X axis. Is this normal or I need to adjust something to make it less. thanks
Old 09-14-2007, 08:43 PM
Syil_Australia is on a distinguished road
David...
That is less than 1 Thou"......0.0006 inch. I would say that is pretty good. How much accuracy do you need....
cheers
Frans
Old 09-15-2007, 12:00 PM
thanks for your reply. Since this is my first machine, I just don't know how much I shall expect. Is there something called "zero backlash ball screw"?
Old 09-15-2007, 03:42 PM
NC Cams is on a distinguished road
Yes, there are - they are usually ground as you need to have a "gothic arch" raceway" and hand selected ultra precision balls to get it.
You also need special, HEAVY preloaded, HIGH CONTACT angle ball screw suppoort bearings to further rid yourself of backlash.
Do an "extrak" search on the CNCZONE - I went thru a treatise on what I did to create a zero backlash system in excruciating detail. ALthough the machine differs, the procedure remains the same...
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 03:35 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
Re backlash phil spanner Mechanical Calculations/Engineering Design 0 09-08-2005 10:57 AM
backlash MIKE JEFFERS Benchtop Machines 4 04-21-2005 11:26 PM
Backlash Nut !! craftech DIY-CNC Router Table Machines 5 12-06-2004 11:14 PM
