Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 08-31-2007, 02:52 PM
Simonetz Tamás is on a distinguished road
Question How to control coolant by G code?
I don’t know how to connect the pump with the control board.
Someone can help me?
Old 09-01-2007, 12:22 AM
syil is on a distinguished road
My staff have been reply you,please check.
xushuo
Direction,Commitment,Follow through
Old 09-01-2007, 01:05 AM
xushuo
What? I don't understand.....
Old 09-01-2007, 01:44 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Hi Simonetz,
The SyilAmerica web site has some documentation on the support page for the coolant connection. They have some wiring pictures and show how to add an outlet to connect the power cord for the coolant system pump on that support page. I believe this outlet will supply the control for the power on/power off to the coolant pump.
I will probably be adding this outlet to mine this weekend and if I get the final colored coat of fiberglass epoxy applied to my flood coolant base I will position it under my SX3 and be closer to getting my flood coolant system running. Hope you are able to go to the SyilAmerica site and get this information so you can get your system going.
Regards,
Wes
Old 09-01-2007, 01:54 AM
Thank you, I check that website!
Old 09-01-2007, 09:15 PM
look like your web www.syil.hu also need this documents or video...
Xushuo
Old 09-03-2007, 11:50 AM
Ok, we did it. It works well. I will put on some pictures about it!
Old 09-03-2007, 12:17 PM
metalworkz's Avatar
Hi Simonetz,
Great! Glad you got it working. Yes, it would be good to see any pictures you can post.
Regards,
Wes
Old 09-03-2007, 12:43 PM
I insert some pictures. I hope it's clear.
http://kepfeltoltes.hu/view/070903/c...toltes.hu_.jpg
If you have any questions I will try to answer..
Old 09-03-2007, 12:44 PM
Boss 8 coolant control sharp-shooter Bridgeport and Hardinge Mills 10 06-21-2007 07:13 AM
I´m confused G-codes are the only code? engrsc G-Code Programing 6 11-22-2006 07:04 AM
Syil(Spindle, Coolant pump G-code Control Finish) syil Product Announcements & Manufacturer News 4 08-27-2006 10:52 AM
coolant pump control - aftermarket MrMudd Haas Mills 8 03-08-2006 06:24 PM
Spindle speed control and coolant pump Peten General Metal Working Machines 2 11-12-2005 05:07 AM
