| Syil Products Discuss Syil milling machines and conversion kits here! |
| Not familiar with specific machine. BUT am real familiar with bearing fitting. If the bearing is slip fit/no slop on the shaft, it probably has a collar that clamps it into position - simply tighten the collar. IF the bearing fits and is held onto the shaft via press fit, you really need to re-establish a proper fit. I'd be inclinded to chrome plate the shaft and then have it reground to a proper fit by someone who does precision OD grinding. Do a "bearing fit" search on CNC Zone for my repeated diatribes on the proper fitting of bearings to shafts. |
| In the part diagram you will see the locking nut on the top. You remove the top idler bearing and pulley, it is underneath that. They need to be tightened periodically. Say every few hundred hours. Tighten and then back it off 1/16th of a turn. This will give the the proper pre-load. Any tighter and you will burn it up. Loose and you will induce some spindle run out.
__________________ Direction, Commitment, Follow Through |
| bearing lock nut on ball screw, how to? | replicapro | Linear and Rotary Motion | 1 | 01-10-2006 07:28 PM |
| Ball bearing encoders - DIY? | Mcgyver | General Electronics Discussion | 164 | 11-27-2005 12:25 PM |
| Ball-bearing search | medved | Mechanical Calculations/Engineering Design | 5 | 11-23-2005 06:30 PM |
| Ball Bearing Size | kenbeth | DIY-CNC Router Table Machines | 1 | 02-04-2005 12:13 AM |
| Angular Contact Ball Bearing ? | sendkeys | General Metal Working Machines | 2 | 06-24-2004 02:06 PM |
