Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 07-27-2007, 05:36 AM
Chrisjh is on a distinguished road
R8 Collet Holder Tool Setter
I have an ER32 Collet set to suit my Syil CNC X3 Mill (R8 Spindle) but found it a pain to tighten the collet in the machine. I had seen professional "toolsetters" but they cost far more than I was willing to spend.
Generally they consisted of a "C" section of steel bored to suit the collet holder and were able to be bolted to a bench (tool side up) so tools could be easily secured in the holder with the collet spanner.
I needed to find some "C" section steel with a 120mm wide dimension. I was dreaming. No one in Australia seems to manufacture a cross section that I needed.
I came up with a design that uses 2" ID steel pipe that negated the need for the "C" section and most of the parts can be made on a lathe and a mill with an indexing setup. The 61mm hole in the clamp was machined in the CNC mill.
The photo shows the finished product held in my bench vice and is self explanatory. I have attached a zip file of all of the drawings that I generated so that others can make a similar setup if they choose.
Regards
Chrisjh
Old 07-28-2007, 03:41 AM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
By far the best system I have seen to date is the Royal tool system for fixed tooling. I haven't seen too many tool setting setups myself. Maybe you could educate us on the use of your tool setting device with a few more pictures?
Royal R8 Quick Change
We will be carrying this line shortly.
Direction, Commitment, Follow Through
Old 08-04-2007, 06:42 PM
keen is on a distinguished road
Have you seen the TTS system? http://www.tormach.com/Product_TTS.html
this would be more ridgid and I imagine cheaper than the Royal system.
Old 08-05-2007, 11:17 AM
MichaelHenry is on a distinguished road
I believe that this system relies in part on the spindle nose being ground flat and parallel to the table. Would a Syil mill have that feature?
I also believe that you will need the TTS 3/4" R-8 collet, are a standard collet that has had it's nose ground down a bit.
Mike
Old 08-05-2007, 11:37 AM
snowshovelbmx is on a distinguished road
The TTS system does look much more rigid though! and seems like it would be easier for a powerdrawbar and tool changer if needed
"you don't even need cnc if your handy with a torch"
Old 08-05-2007, 12:50 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Take a Piece of Rectangular Stock and a Ball End Mill and make your own. Actually I used a Lathe to make mine, but I don't know if you have a Lathe.
I Made 4 of these.
R8, CAT 35, CAT 40, and CAT 50 all with the keys. It was a Lot of fun and i never have to wait for a fellow coworker to finish working with his tool. I just use the ones bolted to my tool box LOL.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-05-2007, 03:37 PM
Mike you are right about the spindle nose - you could check it with a dial indicater and if needed take a skim with a carbide lathe tool held in the vise. - then it is perfect.
Old 08-05-2007, 05:35 PM
I wonder if a similar approach could be used for the 3/4" R-8 collet - stick a bit of 3/4" stock into the so that the end is recessed slightly below the nose and use the same carbide tool to turn the end of the collet flat.
Mike
Old 08-05-2007, 06:03 PM
thats not a bad idea, and Im sure that it would work fine. in fact if you went through all this trouble why not make your own tool holders too?
chris.
Old 08-05-2007, 08:06 PM
tobyaxis's Avatar
Moderator
chris.
A quick solution to using a piece of stock laying around the shop is in no way trouble. If you order one, the best delivery will be next day excluding Sunday. So if you need one now you make one, not wait till Monday Morning to Order one and not get it until Tuesday at best.
BTW: 99.99% of Machinists make their own tools for various tasks when the shop doesn't have it. Personally I have at least a dozen personal tools for specific applications that can't be bought in any catalog. Most of them for setting up and the rest to make life a little easier.
I guess this is how we separate the Machinists from the other types in this trade.
Cheers!!!!!!
Toby D.
Schwarzwald
  #11   Ban this user!
Old 08-06-2007, 03:49 PM
Yes I agree, making tools that cannot be bought is a great way to usually make things faster and/or easier. Although it could be considered trouble when the tooling can be bought for a small cost. If you have the time than go for it but sometimes the tools can be bought for less than it would cost to make your own. The tool holders that you buy are hardened and ground so I think I would rather buy say a solid collet or collet holder from them but maybe a fly cutter or drill chuck arbor could be made easily. This is where you have to use your own judgment.
chris.
Old 08-06-2007, 05:19 PM
tobyaxis's Avatar
Moderator
chris.
If you read the original Post you will see that this is for Tool Holder Set Up, not the Tool Holder itself.
I would never make a Tool Holder to place in any Machine Taper that wasn't Ground to spec.
Expandable Arbors, Tap Extensions, Silting Saw Arbors and Hand tools only, Not Tool Holders LOL
Cheers!!!!!
Toby D.
Schwarzwald
Mach3 and Tool Setter ints99 Mach Mill 1 07-31-2010 05:29 PM
7x10 headstock collet holder? Tim Wiltse Mini Lathe 2 04-23-2007 07:43 PM
Tool setter alarm Nine Blue Mazak, Mitsubishi, Mazatrol 3 02-17-2007 06:00 PM
50 taper tool setter utengineer04 Work Fixtures and Hold-Down Solutions 4 09-12-2005 02:16 PM
tool setter ACME General Metalwork Discussion 8 07-30-2005 11:15 AM
