Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 07-08-2007, 06:03 AM
david_geng is on a distinguished road
How do you deal with the noise from the spindle pulley?
I got a Syil CNC SX3. The problem is that there is a bit noise from the mill head, which sounds like something loose there, it's not squeezing, not continuous even noise.
I disassembled the head and located the problem between the belt pulley and the motor spindle. I don't know what's in the original SX3 mill, with the Syil SX3, the pulley has been changed to bigger size.
I reckon the cause of the problem goes down to the motor driving circuit, which simply uses the Hall sensor communication for the brushless motor. Such circuit generate big torque pulse somehow. And such torque takes the advantage the tiny gap between the spindle key and the belt pulley to make a kind of knocking noise.
So I wonder if there is any glue like grease can put there? I've tried lithium gre ase and copper grease without big difference.
cheers
David
Wear in spindle splines or pulley cut more Bridgeport and Hardinge Mills 11 07-03-2007 06:31 AM
Way Oil and Spindle Noise ETM Shop Syil Products 14 01-28-2007 09:06 PM
Removing pulley from Taig spindle warpedmephisto Taig Mills & Lathes 13 04-02-2006 04:53 PM
Porter cable spindle noise reduction or alternative? paulr4 DIY-CNC Router Table Machines 6 03-26-2005 12:56 PM
spindle electrical noise balsaman General Electronics Discussion 9 10-21-2003 08:41 PM
