Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 06-09-2007, 02:23 PM
bcnc is on a distinguished road
help! X3 spindle problem
Long story short, Spindle wouldnt work called Syil sent me new boards except one in the back cover and new spindle motor. Installed everything still does not work? WTF! Anyone experience anything like this or am I a doffus? thanks in advance Brian
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 06-09-2007, 05:45 PM
askman is on a distinguished road
if everything is free, sounds like wiring issues. (or possibly motor)
Old 07-21-2007, 11:39 AM
n0f8r is on a distinguished road
front control panel
Does your front control panel respond the way you expect?
My spindle would not start either - switching on the machine would illuminate the front panel display - but the start button on the front panel would not do anything - in manual or CNC mode.
Thankfully Richard (of Syil America) was visiting the UK (checking out the UK franchaise) shortly after I purchased my machine and was able to fix it on site. There are some spacing screws behind the front panel that needed adjusting to ensure the buttons will make contact.
Not sure what I would have done if Richard wasn't here - if this sounds like your problem then contact him for the details.
regards,
Kevin.
Old 07-21-2007, 10:33 PM
syil is on a distinguished road
is it new edtion of sieg control board? or old edition?
China.Syil
Direction,Commitment,Follow through
Old 08-15-2007, 04:09 PM
short circuit problem?? Syil - please FACTORY TEST !!!
I experienced the same problem again intermittently after Richard's adjustment, and finally disassembled the front panel myself.
What I found was that the digital height gauge bar (see arrowed attached pic) which has a black matte front is bare alumunium at the back.
This bare aluminium back faces directly onto exposed soldering pins on the control circuit board which I believes allows the possibility for short circuiting the controls, causing unpredictable behaviour.
I put electrical insulation tape over the exposed pins (see attached pic) where they might come in contact with the bare aluminium back of the gauge bar and re-assembled and now my spindle starts every time (so far).
Of course it could also be that it works now because I ended up fiddling with the spacing pins again... whatever, Syil, you need to test your machines before you ship them, I don't think anyone will object if you add a little to the cost - especially if you advertise the fact that the machine has been factory tested.
Otherwise I am very happy with my machine so far.
regards,
Kevin.
ID:	42163   Click image for larger version
Old 08-20-2007, 02:05 AM
this is a design fault by sieg X3, the ruler very easliy to touch the electonic board.we still not receive sieg regards this problem issue explain.
we suggest them adjust casting of mould to increase space.or reduce ruler size..
but frankly to say we not suggest customers use this rulers.not precision
we are carry carefully inspection after syil america visit.in next shipment,and future machines we will have more ducoments and CDs regards muanul and quickly problem answers.
Syil china.
Old 08-21-2007, 07:35 AM
Chrisjh is on a distinguished road
Thanks Kevin.
This would explain the large number of failures that I have personally seen where the keypad front panel board suffers a catestrophic failure near one of the optocouplers. I have seen 3 so far which I couldn't see a reason for the failure. When this failure occurs it also destroys the 7806 voltage regulator on the main spindle board and also the electronic feedback/positional sensor on the spindle motor itself rendering the motor useless.
By sheer luck my Syil X3 has not suffered from this problem yet and I will be checking ASAP the clearance between the rule and keypad (front panel) board. If I cannot see an easy way to increase the clearance to prevent shorting, I will remove the rule totally from the machine. I don't use the digital readout anyway as I use my machine exclusively as a CNC machine always under computer control so I know where the Z axis is at all times.
My machine did suffer a main spindle motor driver board failure after less than 1 hour from new which I was able to repair myself. My spindle drive board problem involved the failure of the switching chip (with the part number pathetically scratched off it) that generates most of the power rails used in the machine. After 2 weeks of trawling the net I managed to identify the chip and replace it. This fixed the problem. So far I have been able to get 3 spindle drive and front panel keypad boards repaired and tested using my machine but so far I have not been able to get failed motors operational again due mainly to lack of time. It would be much easier if Seig published schematics (circuit diagrams) but this is wishful thinking.
I have been involved also with the "new" digital set of boards offered as replacements for failed boards but I personally do not like the way that the spindle motor comes up to speed. It is far too slow!! You could be well into a cut before the motor attained the speed set in your program. Another thing to note with the "new" digital boards is that all boards must be replaced as a set as there no backwards compatibility with the original set of boards at all.
Regards and thanks for pointing out the clearance problem. I really appreciate this.
Chrisjh in Australia
Old 08-21-2007, 08:02 AM
your machine was frist edition of G control board and PC interface.
right now in our new PC interface board have been include charge pump,also can be plug on power connect.
also,Syil australia shipment total old sieg mainboard.right now total new edition too. i think your receiced our new electonics from frans,right?
Syil china
xushuo
Old 08-24-2007, 04:59 PM
Syil_Australia is on a distinguished road
xushuo.
Chrisjh bought his X3 from us. Chris is very knowledgeable with electronics and has helped us and clients fixed the problems of the boards.. New & Old Edition boards.
With the New edition boards the spindle is somewhat too slow to start and that cannot be altered. To eliminate the chance of the spindle engaging before speed is reached it is best to increase the DWELL timing in Mach3 . This will start the spindle before doing any XYZ moves.
Another issue with the new boards is that the spindle display is not correct if you have the Syil Spindle Speed Upgrade unlike on the Old edition boards.
I think Syil need to remove the Ruler as part of the quality control as the ruler has been the cause of most problems. Would recommend to anyone with an X3 to remove the ruler.. don't need it anyway.
cheers
Old 08-24-2007, 11:52 PM
ZipSnipe is on a distinguished road
Sounds like the Super X3 ain,t so super probably better off with the original X3 ...Right?
  #11   Ban this user!
Old 09-01-2007, 05:36 AM
david_geng is on a distinguished road
what's the part number of this chip? thx
  #12   Ban this user!
Old 09-01-2007, 07:17 AM
Hi David,
The Dual In Line 7 pin chip is a TNY264P from Power Integrations, Inc.
I bought mine from Farnell in Aus so you should be able to source from Newark in USA. Newark Part No is 93K0737.
Symptoms when this chip fails are a dead front panel display caused by no voltage out on the pin marked 5V on the connector on the bottom of the main spindle drive board. Although this is marked 5V on the silkscreen on the board, it should be 6V as it comes directly from the 7806 TO220 regulator.
Be careful however because I have seen several dead spindle situations caused by the sliding part of the depth vernier shorting out on the front panel keypad board. When this happens a catestrophic failure of the mill generally results. The short takes out the 7806 regulator on the spindle drive board, an optocoupler (and often tracks and resistors) on the keypad board , and blows the hall effect devices in the spindle motor itself. I have yet to identify the hall effect devices but have purchased some generic devices from Farnell to try to repair a couple of blown spindle motors.
I have successfully repaired 3 blown keypad boards and 3 spindle drive boards so far and am trying to repair 2 spindle motors when I have some time (maybe this week with any luck).
Have a look at the instructions that I posted this week on this forum for modifying the keypad board to give an additional 2mm of clearance between the vernier and the board. I have done this mod to my machine and I am now confident that mine will not short out now.
Lots of luck and if you need help do not hesitate to post again. I am only too happy to assist if I can.
Regards
Chrisjh
Sieg X3 spindle problem (?) kevin.doherty Benchtop Machines 9 05-18-2007 10:09 PM
Spindle Problem - Help! bcnc Syil Products 5 05-03-2007 02:49 PM
spindle problem with tnc 151 PRIOR666 Bridgeport and Hardinge Mills 7 05-02-2007 10:45 AM
reverse spindle problem bala955 Fanuc 1 03-08-2007 06:24 PM
Spindle problem? GalaticDan Mechanical Calculations/Engineering Design 2 09-20-2005 06:55 PM
