| Syil Products Discuss Syil milling machines and conversion kits here! |
#37
| I too had problems with my old electronics, shorting on the scale. Here is a list of components I had to replace: Code: Main board: Designator Package Replacement part 7806 TO-220 ST L7806 Q1 SOT-23 MMBT2907 Q2 SOT-23 MMBT2222 Q3 SOT-23 MMBT2907 Q4 TO-92 PN2222 Motor: Quantity 3 hall effect sensors. Old part number was UTC U18, replaced with Allegro A3280. http://www.utc-ic.com/spec/U18.pdf Front panel board: Designator Package Replacement part R22 1/8W TH 47 ohm U3 SO-14 ST LM324 U2 DIP-8 X9C103P U7 DIP-4 Fairchild H11A817C U8 DIP-4 Fairchild H11A817C I since have received the upgraded boards. The circuit interface is quite different between the front panel and the main board, it is some kind of synchronous serial interface and it seems like it is polling the pushbuttons. In my journey to upgrade to CNC I have come up with a plan. The Syil spindle board is not the best because it does not have fast ramp times and I'm unsure how good semi-rigid tapping will work with that. I don't really want to use the old main board as it is pretty dodgy. I occasionally had to whack my e-stop relay to get the machine to work and it does not have isolated inputs. My plan is to use an aftermarket brushless amplifier for the spindle with analog inputs. The old front panel controller should work with this and I can also easily interface it to Mach3. With the addition of a simple relay I can select from the front panel or Mach3 control. |
#38
| I have been designing BLDC circuitry upto 2KW so I am comfortable renovating the existing unreliable,cobbled together lot. I have used the the MC33035, MC33039 controller setup and they work really well when implemented correctly in proper current mode with slope compensation, and proper PID design of the speed/power control loop. You can even dynamically brake the MC33035, which goes towards solid tapping.... I am going to come up with a fix on the whole thing, including some new small control boards. The interface system lost the plot when it went CNC. Before that it still sucked.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
#39
| That sounds like a fun project. I'd like to see what you come up with. I too have designed some BLDC servo controllers for work, around 500W, with CANbus and s-curve velocity profile generation. Right now I think I can find a used brushless amplifier on ebay for $100 or so, and that's my plan. With one of those amps, a SSR for estop, a relay for switching from manual/auto control, and a few discretes I think I will have something. Another thing worth noting is the spindle motor. The "old electronics" motor has a voltage rating of 110V, and the "new" one is 220V. The RPM listed is the same, 3500 RPM. The old amp must have driven the motor differently or something. I think I will switch back to the old motor, and with a aftermarket amp I should be able to get some more spindle speed. This is better than a pulley change because I will still have low speed torque. |
#40
| As far as spindle speed goes, I did notice when I was making repairs to the control boards when I bypassed the digital potentiometer that I could get the spindle speed up to 2500+ rpm. With a working digital potentiometer installed the maximum spindle speed is only 1730 rpm. Neil, definitely would like to see your board design to replace the standard SX3 control boards. |
#41
#42
| Hi Chrisjh, can you please provide details of the switching chip IC please. My board failed only after 2 hours of use (I hope it hasn't blown the main motor controller as well). The problem is that my board was wedged in an it got damaged as I was dismantling it so I now have a broken board which I am wonder in I can repair. So anyone who can provide a circuit diagram I would be grateful, or any advise on where I can get a replacement. Thanks Alex |
#43
| If it is a late model Motor control PCB in the X3 the switchmode chip (u201) is VIPer22a from ST Data: http://www.google.com.au/url?sa=t&ct...kUBsRSFbsF7e8w If it is an early PCB without the piggy back PCB is a TNY268PN Data sheet: http://www.google.com.au/url?sa=t&ct...6NeYNSxXot1gvw I know most of the chips that have been ground off. IMHO the older PCB is a better design. Chinese grown BLDC can't be as good a tried and tested design from Motorola. They don't grind the tops off to hide them from us here. It's so their CN neighbors don't clone them! Neil
#44
| Thanks for these pictures they were able to help me identify a small surface mount resister than just "brushed off" the board (so much for the soldering techniques) when I was pulling out my failed controller. I saw it tumble into a sea of saw dust and filings so I have no hope of recovering it. So can anyone help and tell me what value R23 is on the controller board please - also any help with part numbers would help as well. Thanks Alex
#45
Alex. Can you take a picture of your problem area. I haven't got access to back of SX3 at present, but will have a look if your PCB matches my model PCB's. Are you taking the 7 hour drive to the BBQ? ![]() Neil |
| Sieg X3 spindle problem (?) | kevin.doherty | Benchtop Machines | 9 | 05-18-2007 09:09 PM |
| Spindle Problem - Help! | bcnc | Syil Products | 5 | 05-03-2007 01:49 PM |
| spindle problem with tnc 151 | PRIOR666 | Bridgeport and Hardinge Mills | 7 | 05-02-2007 09:45 AM |
| reverse spindle problem | bala955 | Fanuc | 1 | 03-08-2007 05:24 PM |
| Spindle problem? | GalaticDan | Mechanical Calculations/Engineering Design | 2 | 09-20-2005 05:55 PM |
