| Syil Products Discuss Syil milling machines and conversion kits here! |
| I am new to the Syil mills,Bob CADCAM and Mach3 so thought I'd better try out what I've been learning before looking for work. I was most concerned about the SX3 rigidity and accuracy - and how much I could use it for my Injection Moldmaking work- especially when working with P20 (prehardened steel). Overall for the money it is very impressive! I have made some adustments to gibs and backlash etc and can mill a 50mm circle to within 0.02 of round (div by 25.4 for inch). Cuts very well in the softer materials - and even manages to cut P20 with max revs, carbide D bit cutter - and light cuts. (see JPEGS) |
| Hi thackman - picture shows samples in aluminium,copper. wood and P20 steel - about 35RC hardness. I used HSS cutter for the soft materials without coolant, HSS cutter for the Copper with a smear of cutting oil - and a carbide D bit cutter for the P20 - without coolant. |
| Yeh the stuff we use in NZ is pretty crappy. You may be more able to source free machining grades - big difference. I use any good quality thin cutting fluid such as Rapid Tap - or a thicker one such as Rocol Ultracut thinned with Kero. A razor sharp cutter with plenty of revs also helps a lot. - the cutter will probably get blunt if the copper is a general grade due to abrasive impurities - and will need resharpening. |
| tracing physical samples into CAD | mark_christians | WoodWorking | 4 | 03-09-2007 12:03 PM |
| Tutorials , exercices, samples , mold samples | engrsc | Solidworks | 4 | 02-22-2007 09:24 AM |
| someone want free samples? | E.C | General Electronics Discussion | 0 | 11-09-2005 06:25 AM |
| Need help for making samples | tony85 | Benchtop Machines | 3 | 07-06-2005 06:15 PM |
| Molex Samples | ljoe1969 | General Electronics Discussion | 1 | 06-18-2004 04:23 PM |
