Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 04-28-2007, 11:46 AM
david_geng is on a distinguished road
Is there any document or FAQ for the Syil SX3 mill?
Hi, there,
I just received my Syil SX3 cnc mill yesterday. I'm setting it up in my garage. I think there is need to connect a few wires between the CNC control box and the original mill control box. So far I've connected 2-wire emergency stop connector, a 10pin or so connector, and there is still another connector looking like a power supply no where to go. Can anyone help? thanks
David
Old 04-28-2007, 07:28 PM
dafowfidy is on a distinguished road
Remove the upper pannel, there is a plug up there that it connects to.
Old 04-29-2007, 12:18 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Hello David,
You will find some information on the SyilAmerica website under the support tab. Here is a link:
http://www.syilamerica.com/support.asp
Regards,
Wes
Old 05-06-2007, 01:59 AM
Green0 is on a distinguished road
Yeah why they ship the damn things with hanging dissconnected BS I have no idea.
Sounds like a good way to create issues.
I might still have something not connected. I thought everything was done, and the steppers had no power, so I called and they told me about the control box power supply.
That should be numbered, and under the acess pannel up top there are numbered wires. If you connect those wires to their corresponding numbers on the socket thing (three lead connection), your steppers will get power.
That means they will get warm when you turn the machine on, and not neccessarilly anything else. Mine do just that and nothing more.
Old 05-06-2007, 07:14 AM
syil is on a distinguished road
i have been email the manual to Syil UK.
please contact them for those flies.
becuase the carton if we put the control box connected was too small and hardly to closed.that is reason.
Syil China
Xushuo
Direction,Commitment,Follow through
Old 05-06-2007, 02:47 PM
I understand it ships smaller, but I also think it would eliminate a lot of tech support issues because people could know going in that everything was properly wired, and rule out that possibility.
That might be worth different crate dimensions.
Document about EDM Robine CNC Plasma and Waterjet Machines 4 06-02-2008 02:24 PM
Need Advice purchasing cnc mill.. syil X3 or tormach? petecul Benchtop Machines 3 04-13-2007 06:37 PM
SYIL SUPER X3 CNC mill System antsals General Metal Working Machines 0 10-12-2006 05:23 PM
Mazak document MeRoN Mazak, Mitsubishi, Mazatrol 0 09-25-2006 02:02 PM
Looking for document for CNC new learner a00509265 General Metalwork Discussion 3 08-22-2004 12:28 PM
