Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 04-27-2007, 05:22 PM
Syil_Australia is on a distinguished road
Mach3 Profile for X3 in MM
Hello guys.
This is the MM Mach3 profile that we use for the X3.
cheers
Frans
Syil Australia
Old 04-27-2007, 10:40 PM
syil is on a distinguished road
thank you frans.
xushuo
Syil china
Direction,Commitment,Follow through
Old 05-20-2007, 08:48 AM
sotos is on a distinguished road
Hi
I tried this profile but I can't load the Mach3 with this one. When I choose this profile the Mach3 is opening with a blank layout and the only think you can see is the toolbar on the top. I tried to use it in a second PC but the same problem is still existed as well. Did any one else experienced any problems with it?
Old 05-20-2007, 10:39 AM
AMS_111 is on a distinguished road
Yes, same problem here too! Blank screen on load with this profile using Mach 3 v2.00.65. Syil USA's inch profile works fine though.
Any ideas?
Mark
Old 05-20-2007, 11:05 AM
ata's Avatar
ata ata is offline
ata is on a distinguished road
Blank, but you can open all dialogboxes from menu config. Writedown all configurations manually from the opened dialogboxes. Make new profile and change the value manually with the values from syiel au ;-).
Old 05-20-2007, 02:18 PM
I am just in the process of completing that. When I have finished and tested it I will post it on here for anyone who is interested.
Mark
Old 05-28-2007, 07:23 AM
Chrisjh is on a distinguished road
I had the same problem of blank screen with just toolbar after loading Syil Australia profile. I fixed it by going to the "View" menu dropdown and selecting "Load Screens". From there I selected "1024.set". This appears to replace the "Mach Steel Blue" screen set with the original "1024" screen set in the profile xml file and fixes the problem. At least it did on 2 computers that I use, a Dell laptop and a AMD powered desktop machine. Hope this helps.
X3 profile missing DublJ Machines running Mach Software 1 04-01-2007 01:49 AM
X3 profile missing DublJ Syil Products 1 03-26-2007 10:10 PM
Profile a Sketch djzepp Autodesk Software (Autocad, Inventor etc) 2 12-05-2006 02:00 PM
Help with profile TPPJR OneCNC 30 12-28-2005 12:22 AM
When I profile?? CNCadmin General CAM Discussion 3 06-26-2003 11:39 AM
