Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 04-22-2007, 12:57 PM
Simonetz Tamás is on a distinguished road
Question Machine refpoints? Limit swithes?
Szasztok! Hi!
I have a new Sx3. I made the connection between the machine and the computer. I use the Mach3 software. (please send me Mach3 profile setup for mm)
I dont understand something!
There is no limit switch to stop the engine before the end of the way of the working table?
I can finde two limite switches but they are doesn't work.
Where are the machine refpoints? x0 y0 z0
Heeeeelp!
Old 04-22-2007, 04:55 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Have you tried looking at the Diagnostics page in Mach3? It should help you figure out if your settings are configured correctly for the home/limit switches. The Artsoft web site has some troubleshooting videos that may help you figure out the problem here:
http://www.artsoftcontrols.com/artsoft/videos.htm
Regards,
Wes
Old 04-22-2007, 05:01 PM
metalworkz's Avatar
Hello again,
Frans at Syil Australia had posted this for another person asking about Mach3 profile in MM. See the post below. Regards, Wes
____________________________________________________
Originally Posted by Syil_Australia
Hello Ata..
We have a Mach3 profile setup for MM.
Can you send me an email at info@syil.com.au and I will send you the Mach3 profile.
I assume you have the X3??...
cheers
Frans
Syil Australia
Old 04-26-2007, 01:14 AM
Hi Wes!
Thanks for help! I’m working ont the problem, but I have never used the Mach3 before.
I don’t understand this one position home/limit switch situation, but I try to figure it out!
Tamás
Old 04-26-2007, 01:51 AM
metalworkz's Avatar
Hi Tamas,
Have you tried to download the Artsoft videos or view them? They do have a troubleshooting video that deals with limit switches etc. and I think it may be helpful. I am fairly new to Mach3 also, but I found the videos to be very helpful. I had thought maybe the active low setting for the Home switch may be reversed, but it will probably show up on the diagnostics page with the yellow LED lights on for the M1,M2, or M3 home switches on??
Regards,
Wes
Old 04-27-2007, 03:26 AM
ata's Avatar
ata ata is offline
ata is on a distinguished road
Smile
Old 04-29-2007, 09:10 AM
Hello Friends!
Thanks for all!
I found the problem. The x and the y limit switch pin setup was wrong.
I changed the pin numbers. Now it is OK!
I set up the soft limit switches. I can control the spindle by M codes.
I can't load those videos. I don’t know why?!
I got help from China! Xushou send me the mm setup file!
Thank you Xushuo!
The next step is to set the motor steps.
When I send the working table to the other direction It makes a mistake.
I measured 0,14mm. It happens on the x and z directions!
Can I correct it with the motor tuning settings?
Thanks!
Old 04-29-2007, 09:51 AM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
Exclamation
You can do that. But I suggest you do a little reading on the Mach 3 forum. If you have not downloaded the little book, YOU SHOULD. Tuning the motors, and seting up the ratios is little harder than the switches. + by the time someone typed how, you could have downloaded the book and read it. It really isn't that much, and it will help because it shows screen shots...
Here are some helpful links...
http://www.artsoftcontrols.com/forum...hp?topic=561.0
http://artsoftcontrols.com/forum/index.php
http://www.artsoftcontrols.com/documentation/
Good LUCK...;->
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Limit Switches Haydn DIY-CNC Router Table Machines 1 12-18-2006 03:19 PM
Help with Limit Switches please Imagineering TurboCNC 14 07-25-2005 06:38 PM
How Many Limit Switches SPEEDRE DIY-CNC Router Table Machines 6 07-23-2005 12:15 PM
EX 02 Safety Limit Switch Engaged FANUC 11 SERIES ON NTC MACHINE Epik General CNC (Mill and Lathe) Control Software (NC) 0 02-27-2005 05:20 PM
Limit switches Phoenix-MN DIY-CNC Router Table Machines 0 04-14-2004 02:16 PM
