| Syil Products Discuss Syil milling machines and conversion kits here! |
I'm trying to disassemble my new SX3 to remove the grease. I've removed the bolts from the bearing support plate on the left and right ends of the table, and removed the plate from the left end. I can't separate the table from the motor on the right, however. If I pull hard enough on the table, I move the table with the motor (the ball screw turns along with the motor). Any suggestions? Thanks. |
What I ended up doing was taking a set of feeler gages and using them as leverage. On mine I was not able to pull it directly off but I was able to wiggle it up and down slightly by gently pulling on the motor. So what I did was open a gap inserting the feeler gages into the gap. From here I used the feeler gages as leverage to slight draw the plate off of the pins. I repeated the process with a thicker stacked of gages until it slipped off of the pins. |
Note, My experience may be somewhat different to yours. I am retrofitting a Syil kit to my X-3. Regards, Russell Perth, WA. |
| Trouble | extreme | DIY-CNC Router Table Machines | 36 | 07-11-2010 05:14 PM |
| 8" Rotary Table Disassembly | ChrisJ | General Metalwork Discussion | 1 | 01-25-2008 02:08 AM |
| More PIC trouble | robe_uk | PicStep Controllers | 5 | 10-10-2006 04:13 PM |
| Bridgeport knee clutch disassembly | eatanimals | Bridgeport and Hardinge Mills | 2 | 04-05-2004 07:50 PM |
| disassembly of stepper motors | dhprc2 | General Electronics Discussion | 8 | 06-25-2003 08:09 PM |
