| Syil Products Discuss Syil milling machines and conversion kits here! |
| Help, how to set step per unit in Mach3 Hi, I use Mach3-Profile from SyilAmerica. I will calibrate the machine. Go to Settings-Tab and click the "Set Steps per unit"-button, write down a value e.g 5. Here come the confuse, is the value 5 in mm or in inch. click OK and the machine moved in the right x-axis. The dial moved from pos 0 to 16.5 (x 0.01mm). Anyone can help me? I will work in mm. I think the x-axis move 5mm if I write 5...? (Sorry, my English is limited) |
| Hello Ata.. We have a Mach3 profile setup for MM. Can you send me an email at info@syil.com.au and I will send you the Mach3 profile. I assume you have the X3??... cheers Frans Syil Australia |
| thanks frans. also,it is have download in syilamerica.com too. xushuo
__________________ Direction,Commitment,Follow through |
| Need help for Parallel port connection with stepper HI My name is Manoj, I am also using Mach3 & bit newer to the parallel port connection. Can i request any support I want to control 3 stepper motors, I am having stepper drive. Regards Manoj
| Mach3 Profile setup for mm, SX3
I sent you my email to info@syil.com.au yesterday. Thanks. Ata |
| TORQUE: FULL STEP vs half step | Glidergider | Stepper Motors and Drives | 0 | 02-27-2007 03:02 PM |
| Mach3 Steps per Unit (Belt transmission) | vdKroon | Mach Software (ArtSoft software) | 5 | 02-18-2007 05:42 PM |
| step by step instruction for building controller | avengine | CNCzone Club House | 0 | 04-21-2006 08:24 AM |
| MACH3 Maximum Step Pulse rate | Ken_Shea | Mach Software (ArtSoft software) | 4 | 09-21-2005 09:14 AM |
| Single Step/Half Step Question | Hawkeye | DIY-CNC Router Table Machines | 4 | 11-20-2003 11:28 AM |
