| Syil Products Discuss Syil milling machines and conversion kits here! |
| I am still working out the bugs on my x3, now I have a problem I didnt have before? I cant control the spindle from my laptop (mach3) I can hear a relay or something clicking in the machine but nothing happens and on the spindle control on my computer screen there is a -1 in the S-vo box? I can turn it off cnc mode and manually turn on the spindle. On the diagnostics screen when I click on the toggle button the output light comes on and I hear the clicking in the machine. Any ideas? Getting tired of chasing these problems Thanks Brian |
| Hi Brian, Have you used the driver diagnostic test to see if the machine is under mach3control? I had some similar problems and usually check to be sure the machine is under Mach3 control if I have any kind of a control problems. I ended up removing a wireless LAN card and all the unnecessary files that were loading on my laptop to have better control. -Wes |
| Problem I had the same problem. I ended up replacing the spindle control board, and thta fixed the problem.
__________________ I don't give a damn if you don't like me, cause i don't like you cause you are not like me. |
| Contact Syil- I'm sure they could help? Have you tried?
__________________ Rodney Hill |
| please sent more info to our US team.if they out of replacemnet parts stock,i will sent to you directly. xushuo syil.com
__________________ Direction,Commitment,Follow through |
| The clicking is caused by a lack of pulses. Sounds like you are running on too slow of a computer or have the kernel speed to low.
__________________ Direction, Commitment, Follow Through |
| HF spindle problem with danfoss inverter | daedalus | General Metal Working Machines | 14 | 07-29-2009 05:49 PM |
| reverse spindle problem | bala955 | Fanuc | 1 | 03-08-2007 06:24 PM |
| Mitsubishi spindle problem | wcopley | Mazak, Mitsubishi, Mazatrol | 16 | 11-08-2006 08:06 AM |
| Spindle problem? | GalaticDan | Mechanical Calculations/Engineering Design | 2 | 09-20-2005 06:55 PM |
| Weeke Spindle Problem | gatorman | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 07-22-2005 04:26 AM |
