| Syil Products Discuss Syil milling machines and conversion kits here! |
| Is it noisy in only one direction? My Y axis driver started running rough, I believe due to a loose connection. It had to be replaced. You should also check the thrust bearing nut and coupling screws. -Jeff
__________________ www.JeffAlbro.net/cnc/ |
Well think I found the problem, the Y axis ball screw is screwed. Ran the table out and there are ball bearings all over the place, looks like the snap ring came off the end of the shaft. Is there a way to get the balls back in the housing or is it wasted? Brian |
| That's a bummer. ![]() If you have all the balls, yes, you can re-load it. Run a search of cnczone using google to find the directions. So, you ran the table out, lost some balls, and then heard the roughness, but didn't know you had lost the balls? -Jeff
| Think I got bearing straightened out. Think I found the reason that happened, the Y motor spases out when I try to run it, like it don't know which way it wants to go? And its louder than the X motor. Any idea? thanks Brian |
my x-axis is doing the same thing, I am waiting on a new driver but I am going to go look at the ball screw right now. Does your y move better at faster feeds? My x will move if I am at a F50. or higher but at a lower feed it just faults out. |
#10
| When I had my Y driver start making a racket... I turned off the power, and started switching cables.... If the problem moves, then you know it is an electronics problem.... if it stays with the axis, it's mechanical. Never connect or disconnect a cable or go into the box with the power on. There may be other dangers to you or your equipment that I don't know about. CNCer beware. Please note, I did this on an X2. On an X3, I think the Z motor is a NEMA 34, so I would only switch X and Y if they are the same type motor. Note also, loose cables have been seen in multiple Syil driver enclosures. Start there. -Jeff
| How to switch axis directions? | juzwuz | LinuxCNC (formerly EMC2) | 8 | 12-31-2006 09:05 PM |
| noisy x axis | fadalman | Fadal | 6 | 12-11-2006 05:32 PM |
| Z axis noisy upon startup | BMackinnon | Haas Mills | 12 | 08-02-2006 07:36 PM |
| Where to change axis directions? | WarrenW | Mach Software (ArtSoft software) | 3 | 02-15-2006 06:32 PM |
| Lower Z axis in both directions when machining a single slot | ngr1 | Mastercam | 8 | 08-04-2005 04:59 PM |
