Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 04-01-2007, 05:05 AM
ata's Avatar
ata ata is offline
ata is on a distinguished road
Unhappy Help, new SX3
maybe somebody can help me to get the correct connection (see pic). The cables come from stepmotor. I find many cables are not tight screwed. I don't have no manual book from sx3.
Thanks.
Old 04-01-2007, 08:35 AM
syil is on a distinguished road
this is 4th axis cable to connnect driver.we packing 4th axis sperately,so didn`t connect it,i will sent the manual for you tomrrow.
also,you can consult more info from your local dealer: http://www.syilindonesia.com/(page in construction)
Your sincerely~
xushuo
Syil.com
Direction,Commitment,Follow through
Old 04-01-2007, 10:22 AM
ata's Avatar
ata ata is offline
loose cable from y axis
not from 4th axis but from y-axis. could you show me please the correct connection. e.g red to d, etc... thanks.
Old 04-01-2007, 10:30 AM
i will reply you by email.
thank you
xushuo
Old 04-01-2007, 06:49 PM
ata's Avatar
ata ata is offline
no connection...? (see fotos, red ellipse)
ID:	34658   Click image for larger version
Old 04-01-2007, 07:19 PM
Flatline's Up! is on a distinguished road
I believe that connector is under the panel at the top/rear of the column. It has 4 phillips screws to remove (on mine anyway). You have to feed that long wire set up under the column rear panel and connect it under the vented 4 screw panel you removed.
(woohooo I helped someone... and mine still doesn't go lol)
Old 04-01-2007, 08:03 PM
Gold Member
InspirationTool is on a distinguished road
Yes, be careful of loose wires... I found several in my X2 enclosure.
-Jeff
www.JeffAlbro.net/cnc/
Old 04-02-2007, 06:57 AM
Syil_Australia is on a distinguished road
Ata.
The X and Y axis are wired the same on the Drivers. Wire the (A driver in your photo) the same as for the B (X axis driver) The Z axis driver is wired differently and looks correct. The A Axis (rotary) is wired the same as the X & Y.
Hope this helps
Frans
Old 04-02-2007, 07:14 AM
Gold Member
Frans, for those of us on the sidelines... is there a reason the Z axis is wired differently? Even if it has different allowed amperage, it is still a 4 wire stepper, right?
Thanks!
-Jeff
Old 04-02-2007, 07:17 AM
ata's Avatar
ata ata is offline
binggo!
yeah, of course, natuerlich...Thanks Frans...
could somebody help me. See the yellow ellipses (the left is now ok) bellow, what for are the connectors...
Thanks.
  #11   Ban this user!
Old 04-02-2007, 08:25 AM
I put that in my post above.
Remove the cover at the top of the machine that has the yellow lightning bolt sticker on it, and you'll see the other end of that plug there...
Good luck
I believe The on in your lower right of the pic goes to the board on the E-Stop plug (although it's hard to tell from your pic)
  #12   Ban this user!
Old 04-02-2007, 09:15 AM
ata's Avatar
ata ata is offline
OK, Flatline's Up!
I will open the cover tomorrow to find the other end of this plug and make foto from it. Thanks.
