| Syil Products Discuss Syil milling machines and conversion kits here! |
| Super X3 Upgrades and Modifications So I would like to start a thread on concepts of upgrades and modifications all of you guys have thought of, wished for, or even done to your Super X3. I just got my machine; I would really like to put a manually operated spindle break on the machine for Tool changes. I am looking in McMaster Carr for a band brake and then the issue, where to put it. Anyway I guess I thought it would be cool to see what other people thought of. |
| Wish List..... Hi dafowfidy, Hm... Let's see, what would I like for upgrades on my Super X3: 1) Way protectors & wipers 2) Tool changer 3) One-shot oiler 4) 5th axis add on Regards, Dan |
| Super X3 And a 8000 rpm spindle could be nice Jeff |
| How about 9500 rpm? Got a gear box coming in 1 week. If it tests out well, We'll put it in the store. Probably $190 for the upgrade.
__________________ Direction, Commitment, Follow Through |
| Jeff |
| if you get that high rpm with gear, you may lost low rpm power. also I feel you only need small cutter for that high rpm, so why not a seperate spindle fixed to somewhere on the headbox? Moreover, has anyone thought about brushless servos, provided they cost just 20% more than the stepper solution. |
| High rpm
You're right David, a separate high speed spindle seems to be a good solution. I'm thinking about a Kress motorspindle (8000 to 24 000 rpm) about 160 euros. Before let our friends from Syilamerica showing their solution. |
| Curious, what are you guys cutting that you need that high of a speed? Brian |
| 3/16 "Streaker" in 6061 is around 17,000RPM. I assume Syil means a switchable Hi/Lo gearbox.
#10
| The additional high speed addons are using R8 inserted spindles. So the 9k spindle is a gearbox that is inserted in the existing spindle. Run out on the existing spindle is a respectible .0004". It's got all the regidity, makes sense to use it. The 30k rpm spindle is air powered. Each spindle only takes away 2" of travel. I've never tried the add another spindle to the side trick. Maybe that works well too, but I fear for the life of the bearings in those little hand tools.
#11
#12
| The rigid tapping option that I have been heard rumors about sounds cool. Now we just need support in Mach3 for it. |
| CNC Fusion X3 Bearing Modifications | MacCNC | Benchtop Machines | 5 | 08-11-2006 12:38 AM |
| software upgrades | colin1544 | AjaxCNC Control Products | 0 | 07-08-2006 06:01 PM |
| BOSS 8 modifications | jonny | Bridgeport and Hardinge Mills | 10 | 02-17-2006 12:13 PM |
| Bob-art and other upgrades. | Scott V | BobCad-Cam | 10 | 02-18-2005 04:15 PM |
| TiVo upgrades | CNCadmin | CNCzone Club House | 7 | 02-08-2004 02:21 AM |
