Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 02-24-2007, 06:59 AM
Legion99999 is on a distinguished road
Spindle controller malfunction w/ My x3
My machine has stopped allowing me to control the spindle with Mach 3, Now when i engage the spindle it makes a clicking sound (once) and nothing happens.
I have to switch it to manuel mode to get the spindle working.
I have tried several different program commands but nothing seems to engage the spindle in cnc mode, it leads me to believe i have a bad controller board.
Any thoughts? Any one else have this problem?
Old 02-24-2007, 07:32 AM
syil is on a distinguished road
Please contact our syilamerica for more info.if broken the board we will replace it.don`t worry.
Direction,Commitment,Follow through
Old 02-25-2007, 01:54 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Hi Legion99999,
I had a problem with my X3 spindle when I first started testing but I think my problem was due to a conflict with the Mach3 driver. I would test the driver control and usually it would fail on the first test. I eliminated some unnecessary hardware and cleaned up the applications being loaded at bootstrap and now the driver seems to have better control. I imagine you were not experiencing any problems with your spindle prior to this? I have a minor problem with my circular interpolation leaving flats at 90 & 270 degrees but I am hopeing I can eleviate that by readjusting my gibs. Hope you get the spindle controller malfunction fixed soon.
Best regards,
Wes
Old 02-25-2007, 03:10 PM
danswaay is on a distinguished road
Hi Metalworkz,
I had the same problem with flat spots at Y most negative and Y most positive on the circle.
I found that my Y axis backlash was extreme and checked the coupler cap screws and they were very loose. After tightening them, my Y axis backlash went from .0011 to .002 of an inch. I put that .002 backlash into Mach3 backlash compensation and I can now cut perfect circles etc.
Things to remember:
1) check and adjust all the gibbs on your XY table
2) measure your backlash on XY table
3) what mode of stepper control is Mach3 set to? Stop or Continous?
Old 02-26-2007, 12:19 AM
metalworkz's Avatar
Hi danswaay,
Thanks for replying with the information regarding the flats on interpolation. I will check mine for any such similar problems. I really appreciate your posting this information and look forward to being able to offer something of value myself sometime soon.
Thanks,
Wes
Old 02-26-2007, 11:47 AM
scyan is on a distinguished road
Dans, what do you mean by the coupler's cap screws ?
Thx
Old 02-26-2007, 12:34 PM
Hi Scyan,
I have included a pic of the stepper/ballscrew coupler.
There are two hex cap screws that tighten on the shaft of the stepper motor and also one on the ballscrew. Make sure these are tight and use Loctite blue etc.
Regards,
Dan
Super X3 spindle controller (by Syil) ints99 Syil Products 6 12-10-2006 05:35 AM
controller for spindle so it can tap ZipSnipe Mechanical Calculations/Engineering Design 6 11-26-2006 11:24 PM
Spindle motor and controller suggestions ZipSnipe General Metal Working Machines 2 05-12-2006 09:21 PM
Designing Spindle Speed Controller - Need Digispeed Specs abasir General Electronics Discussion 2 09-18-2005 02:28 PM
HobbyCNC controller spindle control? PranksterO General Electronics Discussion 6 07-26-2004 07:40 PM
