Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 02-08-2007, 05:20 PM
keen is on a distinguished road
Smile Steel bench for X3
Hi - While I am waiting for my X3 to arrive I plan to make a bench. I suspect the small bases that come with the machine would not be as stable as a larger bench and would be best bolted down to the floor - especially in earthquake country! I thought I would weld a frame from angle iron and bolt down a heavy timber top - I suppose about 1.2 m long (47") and around 0.65m (26") wide and 0.8m (31.5") high ? I do not know what the machine base to table top surface height is - so I cannot easily work out the exact ideal height for a 6ft operator. I imagine the PC is best on the bench on the right of the machine? - for those who are right handed. - This is why I imagine it would need to be 1.2m long? I imagine a polycarbonate (Lexan) chip screen between the PC and the machine would be sufficient? then I thought about putting castors on each corner to allow moving it around etc - and jack screws beside the castors to take the weight long term and allow easy leveling. - any thoughts or information very welcome!
Old 02-08-2007, 06:32 PM
Gold Member
InspirationTool is on a distinguished road
I'd think about cleaning and if you want to do flood or mist coolant. That will guide your design.
CNC machines can make a TON of chips in a hurry.
-Jeff
Old 02-08-2007, 11:47 PM
Thanks - I plan to put the bench in a workshop corner - against 2 concrete walls - and I will have the Lexan screen on the right side. But yeh, maybe I should also attach some thin raised walls around the bench to reduce the chips that 'fall down the cracks" Cheers
Old 02-09-2007, 12:22 AM
vladdy's Avatar
vladdy is on a distinguished road
I had made a new bench for my old south bend last summer and used 1.5 by 2.5 rectangular box tubing, based on a fairly low overall cost..wound up using large casters [lockable], and put in a lower shelf for a plastic tool / spares compartments..
Also welded in a chip tray that collects 'most' of the shavings, but I also cut without lube, a mix of HSS and carbide cutters..so no splash shielding..
I angled the front and back legs to give a larger support base, while leaving a relatively shallow top mounting surface..I also set the bottom shelf slightly back so that I could get comfortably close to the lathe..
I made pads mounts for the shelf only on the ends where it would normally mount to the bench, so it's fairly open, and easy to cleanup..
If you want to see what the final result was, I can take a couple of quick photos..
enjoy
Old 02-09-2007, 04:02 AM
Thanks Vladdy - I think I can visualise your design - some good tips.
Old 02-10-2007, 07:00 PM
ETM Shop is on a distinguished road
The steel stand that is made for the SX3 is quite stable; I used leveling feet from McMaster to level it.
What it lacks though is proper way to keep coolant and waste off the floor and walls surrounding the mill. To combat this I am building a cabinet that sits around the mill.
Starting with the base, I constructed a table that sits between the mill and stand, I created a sloping surface that slopes in all directions towards the front of the mill so material is easy to clean. I coated it with fiberglass (ugh) and then painted it with a very tough enamel paint from a paint shop.
I chose to add feet to both the stand and the mill.
I am now constructing a cabinet that will sit on drain table and around the mill with sliding glass doors for easy access. I am adding luxeon LEDs below the mill head to illuminate the work piece and the coolant system integrates into the drain table as well.
ID:	31381   Click image for larger version
ID:	31382   Click image for larger version
ID:	31383   Click image for larger version
Old 02-10-2007, 10:30 PM
Looks classy - gives me some more ideas - cheers
Old 02-11-2007, 12:59 AM
syil is on a distinguished road
Very good job.did your connect the coolant?
is it sable,have noise?
Direction,Commitment,Follow through
Old 02-11-2007, 03:08 AM
ZipSnipe is on a distinguished road
Nice camera dude , those have got to be the cleanest hi rez pics I,ve ever seen on this site. Oh yeah the stand looks awesome, good work.!!!
Old 02-11-2007, 06:10 AM
bohica is on a distinguished road
Here is another example of a mill stand. It is designed for full flood coolant. Although it is not yet completed, you can get the general idea.
Construction is 1/4" angle and plate for the structural frame with 16ga steel and some 1/8 angle for everything else. Vibration isolators are installed on the mounting pads, and the leveling feet shown will also serve as vibration isolators as well.
There is a 15 gal cooling tank in the base and plumbing to carry the fluid to the mill plus a quick disconnect fitting for a hose near the front. All of the electrical is condiuted out of sight. There will be switches on the front for both lighting the and coolant pump. The mill base will be screened to prevent chips from going under the mill to the drain.
ID:	31413   Click image for larger version
ID:	31414   Click image for larger version
ID:	31415   Click image for larger version
  #11   Ban this user!
Old 02-11-2007, 07:15 AM
very good design.you konw Syil just prepare to make a bench of our CNC x3 and x2.so i think we can learn somthing from customers.
  #12   Ban this user!
Old 02-11-2007, 07:58 PM
Flatline's Up! is on a distinguished road
never used flood coolant before, how big of a mess does it make? Is it necessary to put up lexan splash walls (if so, how high?) or is just a drain table like pictured above good enough?
Trying to get my plans together for mine as well.
Thanks,B
bench top mil with Cat 30 or 40 spindle triump Benchtop Machines 1 10-16-2006 10:54 PM
X2 Stand or Bench RTP_Burnsville Benchtop Machines 4 06-10-2006 06:50 PM
My new work bench. xyzcnc General Metalwork Discussion 4 04-20-2006 12:16 PM
A new bench for my mill. yukonho Benchtop Machines 5 12-29-2005 07:35 PM
What is Available in the Bench CNC Machines? Willyb Benchtop Machines 0 09-14-2005 05:18 PM
