Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 02-06-2007, 06:07 PM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
Syil Machine Step Calculation
Our stepper drivers are designed and built in-house. As far as I know, there is nothing out there like it. In the same driver, you can customize how many steps you want to a much higher degree than most drivers. Since it is unique, here are the steps you will want to input in your controller based on our stainless ball screws and computer speed:
Ball Screw Calculations
Ball Screw is Metric 5.08 TPI
Stepper per rev 200
Micro Steps
2 4 5 10 20 25 50 100
2032 4064 5080 10160 20320 25400 50800 101600 Steps per Inch
Maximum Traverse Speed at 25000 Hz
738 369 295 148 74 59 30 15 Inches Per Minute
Maximum Traverse Speed at 35000 Hz
1033 517 413 207 103 83 41 21 Inches Per Minute
Maximum Traverse Speed at 45000 Hz
1329 664 531 266 133 106 53 27 Inches Per Minute
Direction, Commitment, Follow Through
Old 02-06-2007, 06:16 PM
Gold Member
These are the resolutions with each step setting:
Resolution
(2 Steps) 0.0025"
(4 Steps) 0.00125"
(5 Steps) 0.001"
(10 Steps) 0.0005"
(20 Steps) 0.00025"
(25 Steps) 0.0002" Default setting on our machines
(50 Steps) 0.0001"
(100 Steps) 0.00005"
So, you can see, resolution can be incredibly small, but at a price of upper end speed.
Old 02-14-2007, 02:53 AM
SPD SPD is offline
SPD is on a distinguished road
I PM'd you. But I'd like to ask here as well for anyone else that can shine some light on this for me.
Lets say the highest resoltuion I need to run is 0.0005(10 steps). This means that depending on my Hz. I can run at either 148...207...or 266 IPM? Is this cutting speed or rapids?
Secondly. What do you mean by the Hz? Other than its a frequency. Thats all I know.
Sorry for the insanely obvious questions.
Old 02-14-2007, 11:27 AM
Gold Member
The speed limits would be in your rapid traverse speeds. Cutting would be slightly less. Also, mechanical limitations from the torque of the steppers would reduce your accuracy while cutting at extreme speed.
Frequency is the speed of the computers printer port and the speed at which the computer can operate it at. Under Mach, ports and pins, you can select your PC speed.
Old 02-14-2007, 12:21 PM
SPD SPD is offline
Thanks!
PM'ing you with more questions.
Wire expansion calculation tltaylor CNC Wire Foam Cutter Machines 12 09-29-2006 08:24 AM
Is this calculation correct? h3ndrix Stepper Motors and Drives 4 02-07-2006 01:08 AM
Deflection calculation software bdrmachine Bending, Forging,Extrusion... 1 09-20-2005 09:01 PM
resistor calculation need help mike10 Stepper Motors and Drives 2 03-29-2005 10:21 PM
Back EMF calculation? OCNC Stepper Motors and Drives 12 12-08-2004 11:03 AM
