Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 01-24-2007, 12:23 AM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
X2 Backlash and Accuracy
I wanted to simulate what a typical customers experience would be when first starting to use the X2. Here’s what I did:
Opened the crate
Setup the unit on the bench
Pluged in the computer to the parrallel port
Measured the backlash (just for fun, didn’t input them in the Mach controller yet) Backlash for single ball nut X2 (.0017” X, .0021” Y, .0025” Z)
Mounted a vise
Placed some stock in it
Milled a 1.5” circle with ˝” 2 flute HSS EM @ .050” plunge 5.5 ipm
Results:
Finish was clean and the hole was concentric .002”. Not too bad for straight out of the box. With some backlash enabling, and a head tram check this machine would produce some highly accurate work.
Direction, Commitment, Follow Through
Old 01-24-2007, 10:50 AM
Gold Member
InspirationTool is on a distinguished road
Wow!
Are the single nuts preloaded with larger balls?
-Jeff
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 02:35 PM
Accuracy zoltan SheetCam 5 12-14-2005 10:14 AM
K2 CNC need help with XYZ accuracy ChristopherWood Commercial CNC Wood Routers 14 12-03-2005 11:20 PM
accuracy? sixpence DIY-CNC Router Table Machines 41 08-16-2005 11:01 PM
Accuracy determination & accuracy improvement rweatherly DIY-CNC Router Table Machines 5 08-11-2005 09:37 AM
