Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Way covers !! Super x3, where and $ ?
    Oct 2006
    canada
    Hey guys, we're looking at purchasing some way covers to protect them as there are tons of chips falling on them and kinda sticking because of the oil... Do any of you have any idea how much test cost ? What are the best materials ... etc etc !
    Thanks !
    Registered bryanrabb's Avatar
    Feb 2006
    Fort Mill, SC
    One suggestion is clean the ways with acetone, ie get rid of all oil. Then use a PTFE spray, or anyother non-film lubricant. I use this on my saws and router and it provides a low COF and does not collect any dust. There are also graphite based dry lubes.
    When all is said and done, more is said than done.
    Gold Member
    Mar 2005
    I got the square bellow from McMaster for my mini mill. Also, google for Gortite.
    I cut the square bellows into two U shaped bellows.
    Just make sure you can get to the ways for oiling.
    -Jeff
    Feb 2006
    Fort Mill, SC
    do you mind telling me the part# for McMaster?
    Gold Member
    Mar 2005
    For instance, see 9742K35 at mcmaster.com
    Also, on the same page (3554) you will see bellows just for way covers.
    -Jeff
    Feb 2006
    us
    http://www.thomasregister.com/olc/Sm...s_Thomson_Part
    Gortite - Linear Way Cover Kits for Thomson™ Rails
    May 2006
    Any pictures?
    Gold Member SyilAmerica's Avatar
    Sep 2006
    I will have some good pictures for you on a the covers sometime this week. Cost on them is around $150 for the set. Covers Y & Z axis as well as wipers on the front of the Y.
    Direction, Commitment, Follow Through
    May 2006
    Great! Looking forward to it. I was planning on using the Gortite bellows from McMaster for the Z-axis at least, wasn't sure if the Y-axis would really need them. But way wipers, I just assumed those where not available. Is this going to be a set I have to buy from Syil America or is it something that is readily available?
    Sep 2006
    The way wipers are common, they just need a few modifications to be functional. The McMaster covers are fine, however I'm trying to find some custom ones that may fit a little tighter. I'm working with a neat idea that allows you to add or remove them without modifying the machine in anyway. No drilling or screws required.
    Sep 2006
    Here is a preview of the way covers kit.
    Gold Member
    Mar 2005
    Hi SyilAmerica... (What's your NAME btw?)
    The Y axis looks good.
    The Z axis concerns me. I made my Z cover the same way, and I manage to get lots of chips behind the cover. I think the chips stick near the edge, and then the coolant washes them behind the cover.
    What's the thing on the left of the column with the round bellows?
    -Jeff
  • Page 1 of 2 12 LastLast
