Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-19-2006, 11:10 PM
scyan is on a distinguished road
How much precision is enough ?
Hey guys, being new to this, I have a question.
We have corrected the backlash that was plaguing our machine and came out with this mechanical backlash
X 0.0015
Y 0.0022
Z 0.0020
We corrected it through mach 3 but I Was wondering how this mechanical backlash stands up to the competition... ?
Also, when doing a circle now.. the fluctuation is always within 0.001 of an inch, plus or minus depending on where we take the reading. Should it be better than that ?
Thank !!
Old 12-20-2006, 01:18 AM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
You should be able to get that deviation to within .0005". Sounds like you are getting closer, just a little more tuning.
Backlash looks ok, but I'd check it again. I'm going to bet it's less than that.
Direction, Commitment, Follow Through
Old 12-20-2006, 01:19 AM
Gold Member
If you compare the backlash to much anything else, you'll have a good sized grin.
Old 12-20-2006, 04:54 AM
Syil_Australia is on a distinguished road
Hello..
It may be worth checking your Axis motor tuning to ensure that the Steps/unit are absolutely correct down to the 0.001". If either axis is not set correctly you will have minor errors that could appear as backlash. Consult the Mach3 manual for the procedure.
cheers
Frans
Syil Australia
Old 12-20-2006, 06:16 AM
Gold Member
InspirationTool is on a distinguished road
Sycan, coming from a mini mill style machine with acme screws, those seems like pretty good numbers.
Question though.... is this on a Syil with the double ballnuts? I would think you could get the mechanical backlash below .0005"?
Also, what did you do to adjust the backlash? Did you have to monkey with the axis bearing pre-load?
Thanks!
-Jeff
Old 12-20-2006, 09:31 AM
No, our mechanical backlash was pretty bad at
X 0.015, Y 0.0218, Z 0.020
This is with the backlash adjustemnts done in mach 3...
I dont think we can adjust the preload on the nuts, maybe Richard or someone else can correct me. As thats what i would like to do to get the best out of it.. Then finetune with mach 3...
Scy
Old 12-20-2006, 09:35 AM
Gold Member
Scyan....
Something is *wrong* with those numbers.
It would seem to me that the problem would be in the ball nuts system or the end thrust bearings. Check your couplings as well.
-Jeff
Old 12-21-2006, 01:19 AM
Gold Member
Something is very wrong with those measurements. We measure every machine before it leaves. We haven't had any over .0002" on the X and Y axis.
Maybe you could tell us how you are measuring?
Have you made sure your steps are correct in your motor tuning? (referring to Frans)
Everything is preloaded. No adjustment is needed.
Old 12-21-2006, 06:39 AM
Gold Member
Sycan...
Are you testing with a dial or test indicator?
-Jeff
Old 12-21-2006, 10:35 AM
To my knowledge its a dial, what is a test indicator ?
Also, just to make things clear. When wanting to test mechanical backlash, one must remove all the numbers in mach 3 (backlash) and make sure backlash is not enabled or do i leave backlash enabled but at 0 ?
And then, where exactly do you put the dial indicator ? We have a magnetic base and an arm to locate it... Do you test backlash on the spindle vs the tables ?
Thanks !
Old 12-29-2006, 10:36 AM
Gold Member
A "test" indicator has a small dial and a small swinging arm with a small amount of travel.
A "dial" indicator has a sliding arm and a large dial and large travel. The test indicator is generally more accurate.
I use a magnetic base to attach the indicator to the table, and indicate against the head of the mill.
Turn off backlash compensation, and then jog by .001" amounts. Count the number of jogs required to get the dial to move the other way when switching directions.
-Jeff
  #12   Ban this user!
Old 01-23-2007, 05:49 PM
david_geng is on a distinguished road
Sycan, have you sorted out the blacklash? Which part casued this problem?
