| Syil Products Discuss Syil milling machines and conversion kits here! |
| CNC doing flat spots on circles.. !! help ! Hey guys, our cnc is doing flat spots when asked to re-create circles... ive attached a file to you can see what i mean.. its a crude representation but you guys will understand right away ! Thanks for any help in advance ! david |
| Don't know if this applies to your situation, but ... I used to see that when machining large radii on a Bridgeport Boss 5, which could only move in minimum .001 increments. When nearing a quadrant (0, 90, 180, 270 deg position), the tool had to move a whole bunch in one axis before it could make that .001 move in the other axis. This showed up on the part as a pretty wide flat at the quadrant.
__________________ Software For Metalworking http://closetolerancesoftware.com |
| I hope this is not the case or that we can fix it, otherwise, the machine is pretty much unusable... Anyone else ? Last edited by scyan; 12-17-2006 at 06:11 PM. |
| flats on circle Scyan, You describe the result. What is the input? G2 or 3 circular interpolation? If linear code (small segments) please post. |
| scyan, Looks like a good time to check your machine for lost motion. When you reach the 12 3 6 or 9 oclock position on the circle, an axis has to reverse and go the other way. Looks on your diagram you have a clasic case of lost motion. Place an indicator from the spindle housing to a tee slot on the table. Set a zero on the indicator . go to incremental feed, .0001" then move the table in .0001 increments until the the axis moves. reset the zero on the indicator and also zero set the axis in question, increment the axis in the opposit direction until the axis moves. Note the reading on the readout. That reading should give you a feel for the amount of lost motion you have. This might be refered to a backlash. If the backlash is too much, then the same procedure should be used but indicate from the casting of the machine to the end of the lead screw. Then from the slide in question to the thread of the lead screw. What you are looking for is something about what you seen when you checked back lash in the first step. It coiuld also be improperly programed reversal error. Hope this -----o never mind. Regards Walt... |
| We had a similar problem on a large retrofitted borer, turned out the backlash in our ACME lead screws was just too much for doing this type of work. We found tightening the nuts up and using backlash compensation was helpfull but the problem was only realy solved when with switch to ballscrews. |
| the syil already has double nut ballscrews.. so im guessing they might be loose ! We'll have to check that out ! I noticed in mach 3 that there were numbers enterned in the backlash section but it was not turned on.. hmmm Im not sure i follow the procedure about the backlash verification, ill have to be in front of the machine and try it out. Ohh, and heres an example of the code with some circles in it.. N1G40 N2G80 N3G90 N4G54 N5M3 S3000 N6 G00 Z0.25 N7 X2.2687 Y2.0669 N8 G01 Z-0.05 F10. N9 X1.2887 F5. N10 G00 N11 G02 i0.001001001 J0. N12 G00 N13 G01 Y1.5841 N14 G00 N15 G02 i0.001001 J0.0 N16 G00 N17 G02 X2.2687 i0.00149 J-0.3636 N18 G03 i0.001 J0. N19 G01 Y2.0669 N20 G00 N21 G02 i0.001 J-0.0001 N22 G00 Z0.25 N23 G01 Z-0.1 F10. N24 X1.2887 F5. N25 G00 N26 G02 i0.001001001 J0. N27 G00 N28 G01 Y1.5841 N29 G00 N30 G02 i0.001 J0. N31 G00 N32 G02 X2.2687 i0.00149 J-0.3636 N33 G03 i0.001 J0. N34 G01 Y2.0669 N35 G00 N36 G02 i0.001 J-0.0001 N37 G00 Z0.25 N38 G01 Z-0.15 F10. N39 X1.2887 F5. N40 G00 N41 G02 i0.001001001 J0. N42 G00 N43 G01 Y1.5841 N44 G00 N45 G02 i0.001 J0. N46 G00 N47 G02 X2.2687 i0.00149 J-0.3636 N48 G03 i0.001 J0. N49 G01 Y2.0669 N50 G00 N51 G02 i0.001 J-0.0001 N52 G00 Z0.25 N53 G01 Z-0.2 F10. N54 X1.2887 F5. N55 G00 N56 G02 i0.001001001 J0. N57 G00 N58 G01 Y1.5841 N59 G00 N60 G02 i0.001 J0. N61 G00 N62 G02 X2.2687 i0.00149 J-0.3636 N63 G03 i0.001 J0. N64 G01 Y2.0669 N65 G00 N66 G02 i0.001 J-0.0001 N67 G00 Z0.25 N68 G01 Z-0.25 F10. N69 X1.2887 F5. N70 G00 N71 G02 i0.001001001 J0. N72 G00 N73 G01 Y1.5841 N74 G00 N75 G02 i0.001 J0. N76 G00 N77 G02 X2.2687 i0.00149 J-0.3636 N78 G03 i0.001 J0. N79 G01 Y2.0669 N80 G00 N81 G02 i0.001 J-0.0001 N82 G00 Z0.25 N83 G01 Z-0.3 F10. N84 X1.2887 F5. N85 G00 N86 G02 i0.001001001 J0. N87 G00 N88 G01 Y1.5841 N89 G00 N90 G02 i0.001 J0. N91 G00 N92 G02 X2.2687 i0.00149 J-0.3636 N93 G03 i0.001 J0. N94 G01 Y2.0669 N95 G00 N96 G02 i0.001 J-0.0001 N97 G00 Z0.25 N98 G01 Z-0.35 F10. N99 X1.2887 F5. N100 G00 N101 G02 i0.001001001 J0. N102 G00 N103 G01 Y1.5841 N104 G00 N105 G02 i0.001 J0. N106 G00 N107 G02 X2.2687 i0.00149 J-0.3636 N108 G03 i0.001 J0. N109 G01 Y2.0669 N110 G00 N111 G02 i0.001 J-0.0001 N112 G00 Z0.25 N113 G01 Z-0.4 F10. N114 X1.2887 F5. N115 G00 N116 G02 i0.001001001 J0. N117 G00 N118 G01 Y1.5841 N119 G00 N120 G02 i0.001 J0. N121 G00 N122 G02 X2.2687 i0.00149 J-0.3636 N123 G03 i0.001 J0. N124 G01 Y2.0669 N125 G00 N126 G02 i0.001 J-0.0001 N127 G00 Z0.25 N128 G01 Z-0.45 F10. N129 X1.2887 F5. N130 G00 N131 G02 i0.001001001 J0. N132 G00 N133 G01 Y1.5841 N134 G00 N135 G02 i0.001 J0. N136 G00 N137 G02 X2.2687 i0.00149 J-0.3636 N138 G03 i0.001 J0. N139 G01 Y2.0669 N140 G00 N141 G02 i0.001 J-0.0001 N142 G00 Z0.25 N143 X2.0032 Y1.2204 N144 G01 Z-0.05 F10. N145 G03 I-0.2245 J0. F5. N146 G00 Z0.25 N147 G01 Z-0.1 F10. N148 G03 I-0.2245 J0. F5. N149 G00 Z0.25 N150 G01 Z-0.15 F10. N151 G03 I-0.2245 J0. F5. N152 G00 Z0.25 N153 G01 Z-0.2 F10. N154 G03 I-0.2245 J0. F5. N155 G00 Z0.25 N156 G01 Z-0.25 F10. N157 G03 I-0.2245 J0. F5. N158 G00 Z0.25 N159 G01 Z-0.3 F10. N160 G03 I-0.2245 J0. F5. N161 G00 Z0.25 N162 G01 Z-0.35 F10. N163 G03 I-0.2245 J0. F5. N164 G00 Z0.25 N165 G01 Z-0.4 F10. N166 G03 I-0.2245 J0. F5. N167 G00 Z0.25 N168 G01 Z-0.45 F10. N169 G03 I-0.2245 J0. F5. N182 G00 Z0.25 N183 X2.2687 Y0.5314 N184 G01 Z-0.05 F10. N185 X1.2887 F5. N186 G02 i0.001 J0.0001 N187 G01 Y0.8568 N188 G02 i0.001001001 J0. N189 G03 X2.2687 i0.00149 J0.3636 N190 G02 i0.001 J0. N191 G01 Y0.5315 N192 G02 I-0.0001 J0. N193 G01 Z-0.1 F10. N194 X1.2887 F5. N195 G02 i0.001 J0.0001 N196 G01 Y0.8568 N197 G02 i0.001001001 J0. N198 G03 X2.2687 i0.00149 J0.3636 N199 G02 i0.001 J0. N200 G01 Y0.5315 N201 G02 I-0.0001 J0. N202 G01 Z-0.15 F10. N203 X1.2887 F5. N204 G02 i0.001 J0.0001 N205 G01 Y0.8568 N206 G02 i0.001001001 J0. N207 G03 X2.2687 i0.00149 J0.3636 N208 G02 i0.001 J0. N209 G01 Y0.5315 N210 G02 I-0.0001 J0. N211 G01 Z-0.2 F10. N212 X1.2887 F5. N213 G02 i0.001 J0.0001 N214 G01 Y0.8568 N215 G02 i0.001001001 J0. N216 G03 X2.2687 i0.00149 J0.3636 N217 G02 i0.001 J0. N218 G01 Y0.5315 N219 G02 I-0.0001 J0. N220 G01 Z-0.25 F10. N221 X1.2887 F5. N222 G02 i0.001 J0.0001 N223 G01 Y0.8568 N224 G02 i0.001001001 J0. N225 G03 X2.2687 i0.00149 J0.3636 N226 G02 i0.001 J0. N227 G01 Y0.5315 N228 G02 I-0.0001 J0. N229 G01 Z-0.3 F10. N230 X1.2887 F5. N231 G02 i0.001 J0.0001 N232 G01 Y0.8568 N233 G02 i0.001001001 J0. N234 G03 X2.2687 i0.00149 J0.3636 N235 G02 i0.001 J0. N236 G01 Y0.5315 N237 G02 I-0.0001 J0. N238 G01 Z-0.35 F10. N239 X1.2887 F5. N240 G02 i0.001 J0.0001 N241 G01 Y0.8568 N242 G02 i0.001001001 J0. N243 G03 X2.2687 i0.00149 J0.3636 N244 G02 i0.001 J0. N245 G01 Y0.5315 N246 G02 I-0.0001 J0. N247 G01 Z-0.4 F10. N248 X1.2887 F5. N249 G02 i0.001 J0.0001 N250 G01 Y0.8568 N251 G02 i0.001001001 J0. N252 G03 X2.2687 i0.00149 J0.3636 N253 G02 i0.001 J0. N254 G01 Y0.5315 N255 G02 I-0.0001 J0. N256 G01 Z-0.45 F10. N257 X1.2887 F5. N258 G02 i0.001 J0.0001 N259 G01 Y0.8568 N260 G02 i0.001001001 J0. N261 G03 X2.2687 i0.00149 J0.3636 N262 G02 i0.001 J0. N263 G01 Y0.5315 N264 G02 I-0.0001 J0. N265 G00 Z0.25 N266 X2.0376 Y1.2204 N267 G01 Z-0.0394 F10. N268 G03 I-0.2589 J0. F5. N269 G00 Z0.25 N270 G01 Z-0.0788 F10. N271 G03 I-0.2589 J0. F5. N272 G00 Z0.25 N273 G01 Z-0.1181 F10. N274 G03 I-0.2589 J0. F5. N275 G00 Z0.25 N276 G01 Z-0.1575 F10. N277 G03 I-0.2589 J0. F5. N278M5 N279M30 % THANKS ! |
| Ohh, I forgot.. does anybody know if we have adjustable ballscrews ? Sorry if its the wrong word.. hehe |
| The gcode looks a little rough. I don't like the lower case 'i' in there and there seems to be zero occurance of G02 XYIJ or G03 XYIJ format commands, and some entries with 5 to 9 decimal place accuracy. I would try a simple circle on the origin for a test of the machine and see how it looked. Although it could be backlash settings, this would typically involve a bit of a dogleg jiggle at each reversal as the tool crosses a quadrant line. I don't see that in your pictorial depiction of the results.
#10
| What do you mean by a center hole from the origin ? Sorry, really newbie here... Also, ill post a pic of an actual result in a second.. so you'll see exactly what it does... |
#11
| Heres the pic of what we did... ill post the code later but it was a basic like 4 or 5 lines of code, just a circle done from bobcad. Here's the code in question... N1G40 N2G80 N3G90 N4G54 N5M3 S3000 N6 G00 Z0.25 N7 X0.4375 N8 G01 Z-0.05 F5. N9 G03 I0. J0. N10 G00 Z0.25 N11M5 N12M30 Last edited by scyan; 12-17-2006 at 09:18 PM. |
#12
| scyan, I am going to out of town for a few days. Have to make enough money so I can play on these forums. Try checking for "backlash" the way I mentioned. If your confused, welcome to the club but get with HuFlung via EMail, may he can help you out. I will be able to help you out Wednesday night. Wish I could say "Hope this helps" but we don't pos ta say that no more. That is, that is what I have heard somewhere. Try it once and see if it makes more sense when you are trying it in person. You might want to bolt a 123 block to the table, then you can check both axies, I think you are using X and Y and showing the errors at reversal. Regards Walt... |
