Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-09-2006, 06:46 PM
ints99 is on a distinguished road
Power Supply
Can anybody comment,
should the drivers power supply under zero load give output voltage measurements close to 100V ?
Its rated 110V..250V, 50/60Hz and output should be 48V 10A. My setup was configurad for 110V, but I need it for 250V.
The small power supply is corrected - instead of +12 and -12 = 24V I am using now zero and 12V = 12V.
What about bigger power supply, is it universal as it reads? Or, there is some v
voltage adjustmend potentiomenter on the power supply. Do I need to adjust it?
Regards,
I.
Old 12-11-2006, 01:01 PM
No, but sometimes it is very useful to pay attention, are you measuring DC or AC on switching power supply ;-)
So, it is actually more like 45V DC ;-) And anything is powering up well.
But I suggest - if you are receiving the same power supply, i.e. meanwell SP-500-48, there is lot of information available at manufacturers web site
www.meanwell.com (credits to Patrickm, direct link is http://www.meanwell.com/search/SP-500/default.htm
You can even find a lot of CE, TUV etc. certificates ;-)
I.
