Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 12-09-2006, 06:18 PM
nagjames is on a distinguished road
Anyone running these machines in Vancouver,BC State Washington area?
Currently I own a Maxnc. It's running OK but I spend more time tuning it than cutting aluminum. It's a small maching and not rigid enough. I spent $3000 on sw and I need a more robust machine which I can actually work with.
It would be great to see the Syil in action. My main concern is the spindle speed which might be too slow for aluminum.
Thanks,
James
here is my Max:
http://www.jnagy.ca/cnc
Old 12-11-2006, 11:34 PM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
Will be soon. Just shipping one to the WA area.
The spindle upgraded speed of 3600 is terrific for aluminum. I'm not sure what your Maxnc weighs in at, but 400+ lbs sure adds alot of cutting power to your work.
Direction, Commitment, Follow Through
Old 12-12-2006, 03:46 PM
I'm not comparing your mill to the MaxNC. It's a different league. Max is a great learning tool but cannot be used for serious work. It needs constant tuning and adjusting gibs to perform. One advantage of the max is that the spindle can go as high as 9000RPM (only .2 horsepower). I mostly cut small alu parts as a hobby for now. The accuracy is around +-.001" on a 2" part.
If I'm lucky it's better.
The concern I'm having with the Syil is that I cannot achive high IPM with smaller cutters because the RPM is too low. ( for me high IPM is around 30IPM range )
for example:
using a 2 flute .125 carbide cutter with chipload per tooth .001 at 3200RPM ( it's not a good Idea to run a mill constantly at the highest RPM)
I only get around 7 IPM on the good side I'd be able to cut much deeper
I got the chipload data from:
http://www.niagaracutter.com/solidca...edfeed.html#nm
Your google rating is going higher and higher. I think you have a good mill and I'm considering it in the future. no rush for now
Do you ship to Canada as well? Would you know how much duty would I have to pay ? If the mill was made in the US there would be no duty because of NAFTA. But if it's assembled in the US that could reduce the duty -I think. The tax is 13%.
Thanks,
James
Old 12-12-2006, 06:56 PM
Gold Member
Thank you for the complements. We are working very hard to make good value in our products.
I get 7 IPM as well in my calculations.
I think the question is correct, what would be the depth differance. How far can you plunge with your MaxNC?
Old 12-13-2006, 11:13 AM
jinu117 is on a distinguished road
Where is the google rating?
Kind of funny Niagra cutter which I have gotten some from (mcmaster carr) has good feed chart in there... thank you
