Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 11-30-2006, 08:50 PM
jinu117 is on a distinguished road
I would like to setup XYZ limiter.
Long story short, due to some design of the machines, I am actively looking to find a way to attach limit switches to SX3 controller box to protect potential further issues I can see down the line. I am bit tired of idea of referecing machine to home for keeping myself safe each time machine is turned off as well as possible mistake i could make.
Any help would be appreciated.
Old 11-30-2006, 09:56 PM
Greolt is on a distinguished road
Jinu
You can make the homing switches to do double duty as limits.
If you have the Syil setup have a look at this thread to see how I put
tabs in to activate both ends of travel as limits.
http://www.cnczone.com/forums/showpo...1&postcount=48
However I have found that I do not need the limits and use the soft limits in
Mach instead. The soft limits work very reliably for me.
You really must reference after powering up. It is the only way to let Mach
know where everything is. We're only talking short travels so it happens
pretty quick
Old 12-09-2006, 02:59 PM
ints99 is on a distinguished road
What about rotary table? I think, also A-axis will need some homing switch? Or not?
Regards,
I.
Old 12-09-2006, 03:32 PM
I can't comment on a rotary axis as I don't have one.
Old 12-11-2006, 11:51 PM
SyilAmerica's Avatar
Gold Member
SyilAmerica is on a distinguished road
A axis does not require any limit switching. If you wanted something on the A axis, you would need some type of switch and trigger attached to some point on the 4th axis rotory table. Could be easy to do, but I really don't see a function of it.
Direction, Commitment, Follow Through
Old 12-12-2006, 02:06 PM
I am not sure how accurate can such device for a-axis would be to be honest unless direction is limited to one way for checking. When I have some time, I surely will put liiter the way Greolt has set his. That should prevent any mistake I could possibly make...
Old 12-14-2006, 01:25 PM
lgreeves is on a distinguished road
Why don't you want to home the machine after the machine is shut down?
