Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 10-28-2006, 10:35 PM
Woodenspoke is on a distinguished road
Just Got my X2 Mill
I have an Atlas 10" lathe but without a mill it's only half of a working metal shop. I just brought home a Harbor Freight X2 a few days ago. I really needed a mill and this one was about the right size for my projects. I am still awaiting delivery of an Enco milling vise before I make my first test cuts. I pretty much tossed the stock chuck and I will get an R8 to MT2 converter for my Albrecht which I use on the lathe. One note is the Z axis, the backlash is pretty bad. I took it apart but saw no easy way to fix it. What should I expect for the price?
Needless to say I do not want to spend much time manually milling parts and I want to quickly upgrade this X2 to a CNC machine. I have been looking at controllers, motors (steppers) and conversion kits and the options are many. I wish to get a four axis controller kit but I will wait to install the 4th axis. Once the X,Y and Z is running I can make a proper 4th axis mount myself when the time is right.
1. Belt drive is a must, Who's best? KDN or LMS or the cheaper one for $95 (sorry cant remember the name).
2. Best X,Y,Z ball nut CNC conversion kit; Fusion or who ever else makes a full conversion kit? Should I keep the Manual option open or toss the wheels? Is there another non ball mount CNC conversion kit available?
3. 4 Axis controller and motor(Stepper), Gecko (don't see motors) or Xylotex ( I can get 4 motors at the same time). What controller model makes the most sense if I go with Gecko or any other brand?
If there is any other suppliers, specific items or suggestions you have to make my decision easier (or should I say harder) feel free to comment. Of course the software would be Mach2.
One other note it would be nice to keep the whole upgrade at a reasonable price point.
Old 10-29-2006, 01:06 PM
Tim Wiltse is on a distinguished road
Woodenspoke,
I am in the same boat as you. I have owned my X2 for a couple of years now and want to convert it to CNC. The route I am going to go is with the CNCFusion kit with all 3 ballscrews($539), Xylotex 3 axis "ready Kit"($420) and Mach2/3($160). I really don't think I'll need the 4th axis at this point but I might down the road in that case it's $600 for the controller,steppers etc. From what I have read this is a solid setup plan. I should have everything ordered within the next couple of weeks
LAter,Tim
Old 10-30-2006, 09:20 AM
Falcon is on a distinguished road
You might want to look at , cnc Bridges.
Old 10-30-2006, 08:15 PM
CNC Bridges????? No clue did a goggle search and found nothing to do with a Mini Mill conversion.
I did find out that the NEMHA motors sold with the Xylotex kits are double shafted so You can remount your handles on the rear shaft if I deceide to go with the CNCFusion kit. I always worry about disasters and not having access.
I am also in the process of moving within the next few months so the retrofit is going to have to wait till I am settled again. I don't want movers handling a converted Mill.
Old 10-31-2006, 07:31 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I have a ?
Is it less expensive to buy the machine manual and then source and assemble into a CNC machine over getting a ready to go Syil?
If so is it a lot less expensive?
www.integratedmechanical.ca
Old 10-31-2006, 07:38 AM
woodenspoke,
The CNC Bridges machine is made from PLASTIC..no really it's made from plastic and uses the X2 head. I want to machine Delrin not a machine made from it.
LAter,
Tim Wiltse
Old 10-31-2006, 12:13 PM
Pres is on a distinguished road
How prejudice!
Lets see, they use steel machines to make steel parts,
why not plastic machines to make plastic parts?
However, using a plastic machine to make steel parts is probably pushing it too far.
