Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 08-27-2006, 02:59 AM
syil is on a distinguished road
Smile Syil(Advice and Suggestions Inbox)
Since we converted CNC for sieg machines.we received many good suggestion from our clinets.without whom this project would not have been so prefect.so we open this thread for every friend to provide good suggestions for us.no matter machines,service.and delivery.any kind advice,we total welcome.
Thanks for every Syil friends and customers
Here some info of Mr Lou update for us and special thanks for Mr Greg Holt too.
By Mr Lou:
1:Attached are two photos that show how I modified the X axis cover. This change has three improvements.
a. an increase in travel by 0.90 inch or 23 mm in the X direction
b. with out the change the cover will bend if the x axis moves too far.
c. The notch for the wires will let the user remove the cover with out having to unplug the cable from the
controller and pull it out of the covering.
2: Adding a cable tie down is necessary for the Y axis sensor. With out it the covering gets caught on the
table and will damage the sensor. It should also be added for the X axis sensor as well.
3:Add a connector to the A axis if it is ordered. This will allow the user to remove the rotary table when it is not in use.
4:Make a Splash Guard Mounted to pretect operater.
5:Mr Greg Holt use another kind itmes to pretect cable of optical sensor.
ID:	21804   Click image for larger version
ID:	21805   Click image for larger version
ID:	21806   Click image for larger version
Name:	Splash Guard Mounted.jpg‎
Old 08-27-2006, 12:43 PM
Ed from NY is on a distinguished road
Thank you for being so receptive Syil
I would like to add to the list the mod Greolt did on the Y axis travel:
Problem -- as described by Greolt (or at least how I understood it ):
When Syil added the 40mm longer screw to bring the Y travel to 160mm the extra 40mm of travel were added "away" from the column. That meant than when the table was all the way out the spindle centerline would be about 30mm outside the table and only a smaller part of the dovetail would be engaged.
Objective:
To offset the screw/mounts so that we get all that travel with the spindle over the table. See pics 1 and 2.
How did Greolt do it:
1) Greolt added a 20mm block to the stepper mount -- Greolt can you confirm if this has a large indentation at the bottom to allow for the ballnut mount to slide under it ? (pic 3)
2) Greolt machined a 12mm-deep recess into the column so that the screw could travel closer and some 10mm into the column (pic 4)
3) Greolt added a cover on top of it to protect the exposed screw (pic 5).
Greg, I posted this cuz I'm trying to get the mod into my mill which is on Syil's production line right now. Please let me know if I got something wrong... a strong possibility since I have not seen the internals of the mill or of you mod.
Thanks!
ID:	21840   Click image for larger version
ID:	21845   Click image for larger version
ID:	21846   Click image for larger version
Old 08-27-2006, 01:15 PM
Another suggestion based on other people's input in another thread.
Packing:
Americans, Australians and perhaps some other people too seem to be obsessive about packing (lots of filling and very strong boxes). Whether it is justified or not, even if it seems wasteful, it would greatly improve the image of the product if the kits were shipped in a double box (a strong box inside another strong box) ready to survive a drop down the Exorcist stairs
Old 08-27-2006, 03:31 PM
triump is on a distinguished road
So Syil. Are any of these ideas going to be added to your cnc conversions. If so when. I am in the market for a machine and would like to see these inprovments added.
Old 08-27-2006, 03:51 PM
diarmaid's Avatar
*Registered*
diarmaid is on a distinguished road
Also Syil, I visited your site and it says that you accept online payment via paypal but there is no 'buy' button or ordering screen that I could find. There were also no prices on the site?? Do you have to order via e-mail? Thanks.
Old 08-27-2006, 04:21 PM
phantomcow2 is on a distinguished road
I would like to see some improvements to your site and ordering process.
I think that there should be a price list on every product under the description on your site. Also, an order form. ANd lastly, there should be a complete breakdown in prices for individual components in your conversion kit.
So that people who want reduced kits can order, or need replacement parts.
Old 08-27-2006, 06:05 PM
diarmaid's Avatar
*Registered*
I agree 100%.
Old 08-27-2006, 07:15 PM
Greolt is on a distinguished road
First of all I would like to applaud Syil for taking such an open aproach to ideas.
So some small items more as suggestions for assemblers rather than Syil.
Connector under the motor cover. Easy for maintenance. I used computer hard drive conectors.
Lower top of X axis bracket so that screws are below table level.
You'll wish for this is when you have used the machine for a while.
This requires machining.
Connect the machine estop as the controller estop. It has a spare pole on it.(Super X3)
Put the homing switch and estop wires through some ferrite suppression sleeves or rings to help with noise.
I had a problem with my estop triggering, this stopped it.
EDIT; Ed has asked me for more detail on my mods to the "Y" travel.
I will post them on a retrofitters thread I have going here
ID:	21864   Click image for larger version
Old 08-27-2006, 09:11 PM
I remembered another one
The screws have a brass nut to preload the dual angular contact bearings but has no lock nut or locking devise to hold from moving.
I put three washers to take up the space between the brass nut and the flexible coupling to use it as a locking device.
Does it need it? Who knows? Is it easy to do? Too right
Old 08-28-2006, 12:32 AM
this problem also we are very very headache,since we make the web we want to all payment under paypal,but we find it is hardly and impossible to operation in china.
1,paypal never support china credit card,our company must have a US Bank account.
2,paypal back money to personal credit card,not factroy account,that is will be make us hardly to export,becuase china custom will check the dollar income and goods,make them blance.mean,i export goods,must have $ coming record in bank.
3,right now we have been touch some distributor,and them will sell us machines soonly,then they will use online paying.this is we also insist them to do.becuase it is a pretect for customer and seller both.
  #11   Ban this user!
Old 08-31-2006, 07:28 AM
I have one sugestion that would be really helpfull (essential) for Syil converted X3s
Provide some sort of technical information on the electronic components.
Example. What is the rated current per phase on the motors provided?
What is the manufacturers reccomended method to set the amps on the driver to the correct level?
Technical documents on these components are some of the most basic needs for people
setting up CNC on this machine with the electronics provided and should be readily available.
  #12   Ban this user!
Old 09-02-2006, 08:40 AM
1,we have been use cover to pretect the long y axis ballscrew,it is have been finish. as Mr greolt mod,very good advise,and necessary.from today,all machines will be include this,and same as gas spring will be standard parts.
2,we will make same step motor cover as Mr lou advise,it is will become standard parts too as in future order no matter conversion kit or complete CNC super x3.
3,we have been finish all instuction paper and will provide the path to provide download.
thank you every friends.
Syil.
