Hi guys
Today my associate and I both agreed to crack on with Syil's equipment. We are very exited about this and likely to invest into a X4+. We need it mainly for prototyping and as a learning ground for programming and milling on a 4 axis mill.
We've seen plenty of of Youtube low resolution vids of plain cutting passes and others from the X4+. However we have yet found some visuals of the 'quality' it can produce. In terms of finished products/parts of course.
If any of you guys could publish a few aluminum parts that you made with the X4+ in high resolution, that would be fantastic. We are looking for visuals that clearly demonstrate a part's surfacing quality, chamfer or fillet finishes, and ideally, a close-up of any complex geometry finishes.
Some of the EOS camera are capable of capturing some of those details. We'd be eternally grateful if anyone could help us out with this. That would help us greatly to pull the trigger on this model - or another model if the results are to be unsatisfactory!
All the best and thanks in advance guys
