It can be done, but you need to make a support plate for a standard motor.
Have fun
Pablo
Has anyone done a 3 ph spindle motor conversion on the older (2005?) C6? I'm trying to get into the motor enough to read the plate without doing a total tear down, but it appears that the info on the motor plate does not conform to NEMA standards so I may have to remove the motor entirely to get the dimensions. Just thought someone else might already have that info.
My objective is to go with a 3 ph motor and VFD to give me software control over spindle speed, or at least "turn of the knob" control.
Have fun
Pablo
● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
That is an overkill fot that size lathe,1ph is generous enough.
What you have to think of is what the lowest speed will be,what is it by the way?
He didn't mention motor power, just that he wants to usa a 3ph (phase) motor and a VFD, from 0.75 to 1.5hp is enough IMHO
Pablo
My mistake maybe I should have put..."Single Phase"
Yes,yours is not the ideal mounting way though.It can be done, but you need to make a support plate for a standard motor.
