Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Syil Products
Syil Products Discuss Syil milling machines and conversion kits here!
Old 01-02-2012, 05:09 PM
Rodtp is on a distinguished road
Whistling and grunting
On my Syil X5+ when in cnc mode, connected to Mach3 but no prog running, x axis motor whistles quietly. When shift+ left or right arrow to make table move rapidly, it will occasionally grunt and stop moving whilst grunting. In diagnostics, checking movement by asking for a say, 4mm move it sometimes grunts and moves 1 or 2 mm. Computer driver reports excellent. The vertical movement has a much more smooth sound if it is run up to limit and then run down. If stopped and restarted it resumes it's rather grungey sound. Any ideas gratefully received.
Old 01-03-2012, 03:48 AM
neilw20's Avatar
neilw20 is on a distinguished road
Smile
Remove power, and temporarily swap X and Y motor cables.
Power up, and if the Y axis starts doing it (with X commands from Mach3) , the driver is faulty or current limit not working correctly.
If the X axis movement (being controlled by Y axis on Mach3 still exhibits the same problem, then the stepper motor is faulty.
It is possible stickiness int the X axis could cause it, but that is a remote possibility.
By substituting X and Y, wires, cables, PC ribbons, etc, most faults can be isolated to motor/driver/cable PC problems.
Ensure all connectors, crimps, etc are OK. Tug each wire firmly. Loose terminals/crimps/pins can cause all sorts of strange problems.
Particularly motor connectors, which can upset the current mode operation of the microstepping drivers.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-04-2012, 02:26 AM
ramax is on a distinguished road
1. Is the machine latest series?
2.Has it just started doing this or like this from new?
Old 01-04-2012, 11:03 AM
Many thanks for the suggestions. It transpired the X axis is a litle stiff (new machine). I changed the computer for a later one and have reduced the acceleration and speed a smidge and this appears to have cured it.
Whistling motors thuffner3 TurboCNC 0 12-21-2003 09:35 PM
