| Syil Products Discuss Syil milling machines and conversion kits here! |
| asuratman, Thanks for the reply. Yes, this spindle does have power drawbar on BT30 tooling. Syil have it as an option, comes with air over oil actuator on top of the spindle. Your machine sounds like the NT30 (not BT30) with threaded drawbar. Greg |
| Dumb question If your going to add a pull stud, what gripper are you going to use and where are you going to get it. As I understand things now, you have a threaded drawbar?
__________________ Art AKA Country Bubba (Older Than Dirt) |
| ramax I have seen 2 pull studs for BT30 spindle. Both were different dimensions. I guess I will have to buy both and see which one works. bubba, The machine has a power draw bar. Not a threaded draw bar. Greg |
| just look what one you have already and see what angle you have its ether 45 deg or 60 deg Results for Tool & Work Holding:Pull Studs |
#10
| ramax, I have no tooling or pull stud to measure. Its a used machine with no manual or tools. The "Maritool" web site in North America lists 6 different variations for BT30 tooling. Gauge lengths vary form 0.7225", 0.707" or 0.7065" Head dia vary from 0.4705 dia, .431 dia or .549 dia Angles vary from 15deg, 45deg or 60deg. It all depends on the claw in the spindle and the Syil web site has no information. It is looking like the answer is difficult to get. |
| Need Help!- Pull stud? | Ph2011 | Bridgeport and Hardinge Mills | 2 | 06-12-2011 07:07 PM |
| need help with pull stud | pper | Tree | 2 | 05-23-2011 11:02 AM |
| lagunmatic 320 pull stud | topcnc | Knee Vertical Mills | 0 | 03-20-2011 03:09 PM |
| Pull Stud/Retention Knob | KevinV_MEI | Bridgeport and Hardinge Mills | 4 | 01-13-2011 06:57 AM |
| cat40 pull stud ? | axkiker | General Metal Working Machines | 15 | 12-09-2010 02:52 PM |
