Results 1 to 6 of 6
Thread: New on X5+. some questions and pics inside
    Aug 2009
    spain
    Hello guys
    Just received yesterday my new mill. Here comes some pics.
    THE EAGLE HAS LANDED
    Very well equiped, all comes perfectly warped. Just Syil must check weights in his web, they said this machine weights 350 kg, but just only 250kg with stand. Instructions are really well detailed, but only in electrics, some questions are not detailed or even treated
    another point to improve is put more drawing details to new customers. Machine is 73cm wide, but with coolant tray is up to 80 cm. this makes a big diference when you deal with it in a flat, due to this I need to cut the chip tray, nothing important, but if you are not prepared this could be a big issue.
    Here in Spain flats are really small, doors are 80cm in elevator and access doors, home door is only 74cm, and room doors are just 70cm, so you can imagine, machine is entering, and loosing parts due to sablesaw. Also I must dismante X axis motor, 4 bolts and ready to move.
    well, once tray was cut, finally arrives his final destination, so Iīm happy again, motor installed again, but I need a solder and all will be ready for start making chips.
    And now some questions I havenīt found an answer.
    Drawbar. How do you lock it?
    MPG. I have connected to machine but doenīt works. PC hasnīt been installed yet. I suppose will works without PC control. I must active something special. Manual mode has been selected previously.
    Coolant deposit. Capacity? How to clean it?
    EMC2. some of you are using it?
    One shoot lubricator. wich oil I must use? any recomended brand?
    thanks
    Apr 2006
    China
    god...why you are not take off the bottom tary..
    the machine and bottom tary could be seperate.......
    when you use coolant,will flood everywhere...
    i notice one of my dealer use EMC in my place,you can email to Mr len from probotix.com
    he is in my place now...
    Direction,Commitment,Follow through
    Aug 2009
    spain
    Well. If i dont cut tray machine sleeps on street. My home is on a4th floor so is imposible to install there. Only can be done on street and move fully mounted.
    Mpg issue solved. Just need to press on jog more times. until displays MPG
    Any tought about othet questions.
    Apr 2009
    italy
    Quote Originally Posted by syil View Post
    If he removes the tary, the machine will no longer be perfectly warped.
    This is going to be fun when he trys to get the thing running.
    Apr 2006
    China
    Quote Originally Posted by okabum View Post
    Mpg issue solved. Just need to press on axis more times.
    ok,understand.the other questions,sent email to me..
    Aug 2009
    spain
    mail sent.
    1. Need Servo Driver ID'd!!! (pics inside)
      By p27182 in forum Servo Motors and Drives
      Last Post: 11-17-2009, 02:32 PM
    2. Need Help!- Plasma cut quality questions *PICS*
      By tof1 in forum General Waterjet
      Last Post: 09-27-2009, 06:27 PM
    3. My linley Jig Borer- Pics and questions...
      By nate in forum General Metal Working Machines
      Last Post: 12-06-2006, 06:33 PM
    4. Bridgeport series 1 MDI machine pics and questions
      By boringmill in forum Bridgeport and Hardinge Mills
      Last Post: 04-06-2006, 06:30 AM
    5. Setting up my steppers, pics inside.
      By Darc in forum Mach Software (ArtSoft software)
      Last Post: 10-15-2005, 01:33 AM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
