Results 1 to 2 of 2
Thread: using flood coolant quest?
    Feb 2011
    I ran coolant for first time on my X5. It worked out great but now the machine table is full of liquid. The pan under machine is fine as it drained back to pump house, its the machine table vice is mounted to that is flooded full. How do I get it emptied and clean?
    Jul 2006
    Put some silicon grease at the bottom of the vise so that it will diminish the oxidation. Dry it out as best as you can once the session is over. You can lube it up a bit after that. Try to Avoid coolant reaching underneath the table in the ways/guides -- you may get creative here. If you really want to "clean" the coolant, at least on mine, it involves a fair amount of disassembly. I run mine on cutting oil (a very unpopular choice) because I'm lazy, and OCC, like that
    Air blast is generally frown upon as it will push the bad stuff further in.
  1. Which Flood Coolant?
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 06-22-2012, 06:19 PM
  2. flood coolant
    By FUBAR62172 in forum CNCzone Club House
    Last Post: 06-05-2010, 04:32 PM
  3. flood coolant and way oil
    By dlaery in forum Taig Mills & Lathes
    Last Post: 06-04-2010, 12:58 PM
  4. NM-135 and Flood coolant
    By David Da Costa in forum Novakon Systems
    Last Post: 02-11-2010, 10:18 AM
  5. What is everyone using for Flood Coolant Filters?
    By SpeedsCustom in forum Benchtop Machines
    Last Post: 04-15-2008, 12:37 AM
