Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: 2011 v7 vertical machine center
    Apr 2006
    China
    We present v7 machine center,Syil dealer in stocking delivery time within 3 months include china new year.
    more details wait for update:
    Features
    Siemens 802s system,3 axis servo package.
    5.7Inch single blue LCD display screen, showing spindle speed and direction and movement size
    Panel focused on manual control systems, cooling and spindle control
    3 axis servo motor,siemens original
    spindle servo motors. 2.2KW.
    800 X 250mm Size of table
    10000rpm/min High Speed Precision Spindle,NSK bearing.
    380V single-phase AC power supply
    BT30 spindle
    10pcs ATC system with draw bar
    2 x 120mm pre-installed high-speed cooling fan
    high quality casting materials, compact structure
    OEM PMI double nut ballscrews
    Hiwin precision linear guideways
    safety of high-quality electrical components and fast plug
    the integration of the base casting
    Automatic lubrication system pre-installed to protect the rail life
    Coolant/working lights pre-installed
    MPG handwheel controller pre-installed
    CE and CCC safety certification
    Features
    Overall Demensions(L x W x H)***** * - 1550mm*x*1650mm*x*2300mm
    Packing Demensions(L x W x H)****** - 1650mm*x*1850mm*x*2400mm
    Table size*********************************** * - 800mm x 250mm
    T Slot Demensions********************** ** - 16mm
    Weight******************************************- 1200~1350kg
    Axis travel************************************* - X axis: 400mm
    *************************************************** - Y axis: 240mm
    ********************************************** **** - Z axis: 400mm
    Spindle speed**************************** ** - 200~10000rpm/min
    Spindle drive power********** ************ *- 2.2kw Servo
    Spinble taper****************************** * - BT30
    Input voltage***************************** ** - 220v AC 3 Phase
    Repeatablility**************************** ** -≤0.01mm
    Cutter dia*********************************** *- 4~16mm
    Motor torque************************* ****** - X axis motor: 8.0nm
    ************************************************* *- Y axis motor: 8.0nm
    **************************************** ********* - Z axis motor: 8.0nm
    Attached Thumbnails Attached Thumbnails 2011 v7 vertical machine center-1.jpg   2011 v7 vertical machine center-2.jpg   2011 v7 vertical machine center-4.jpg   2011 v7 vertical machine center-6.jpg
    2011 v7 vertical machine center-3.jpg   2011 v7 vertical machine center-5.jpg   2011 v7 vertical machine center-7.jpg   2011 v7 vertical machine center-8.jpg
    Direction,Commitment,Follow through
    Sep 2005
    Indonesia
    Question atc
    Do you sell atc and drawbar only for diy, how much?
    Nov 2007
    The Siemens 802s shows on their (Siemens) website to be a stepper type servo, is that correct?
    May 2008
    Quote Originally Posted by rchunter94 View Post
    802s is for stepper
    802c is for servo.
    If you want to use a 4th axis, the 802c is 3 axis only, you will have to buy another model of controller.
    I really would like to buy the new V7 but lack of response and lack of email keep me on my guard.
    I'm not sure I would send them more than $20000 and never get any replies about my purchase and the 380v really surprise me, another spending for a step up transformer, only have 220v in my shop.
    Looking for a reply from their side. Hope they'll see this post and answer, if not, they will loose another possible customer, ME
    Jeff
    Nov 2007
    Yes I do understand the lack of communication!!
    I have sent emails to several overseas companys and have not recieve any response.
    But they will blog about great things they will do , but without service even before the sale is poor... what about after the sale?
    great service makes great company's
    May 2008
    Yes, they will probably reply something like:
    Syil better than Novakon
    Better design, etc
    But they will not answer what we ask them about their own products.
    Jeff
    Apr 2006
    China
    I`m sorry,it is 220v AC 3 Phase.
    also,we use 802s,and v7,it is full servo machines. no any relative with stepper..
    but problem it is only for 3 axis workings....
    if add 4th axis ,the cost not cheap..
    we are also communicate with funnc wait for them quote 4th axis controller cost..
    Jun 2007
    ireland
    Give credit where credit is due. It is a nice machine, looks well finished, has a toolchanger, coolant etc.
    With it being 3 phase it wont be for us, but that comes with the servo's and controller.
    It will probably be quite a bit more expensive if it makes its way to Europe so would probably be as cheap to get a good used 2nd hand Haas or Bridgeport VMC over here.
    Still it is a very nice looking machine which I wouldn't mind having.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Quote Originally Posted by syil View Post
    Looks like a nice control.
    The 802S is listed as stepper motor controller
    SINUMERIK 802S base line CNC from Siemens Energy & Automation, Inc.
    www.integratedmechanical.ca
    Jun 2007
    ireland
    Quote Originally Posted by DareBee View Post
    Same one as used by optimum on there cnc machines with stepper motors.
    Optimum Machines: F100CNC
    The servo version is used on these
    Optimum Machines: F100TC-CNC
    In this catalogue several of the machines used 802S control also
    http://www.optimum-machines.com/prod...nes/index.html
    Nov 2007
    Yes it is a very nice looking machine!
    Most people will not have 3 phase power, but a phase convertor could be an option.
    Just wondering what the price will be ?
    Low 20's I am guessing with Seimens controller is made in that country anyway.
    Jun 2007
    ireland
    With servo systems, phase converters are not recommended generally.
  • Page 1 of 3 123 LastLast
    1. Newbie- Tooling Offsets - Vertical Machining Center
      By CNCheese in forum CNC Tooling
      Last Post: 09-07-2010, 12:33 AM
    2. Problem- Beaver VC 15 Vertical Machining Center
      By MACHINEYARD in forum General Metal Working Machines
      Last Post: 11-11-2008, 02:40 AM
    3. DMG Deckel Maho Vertical Center DMC 1035V
      By CNCCS in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 07-12-2008, 12:58 AM
    4. Need Help!- CNC Vertical machining center
      By soumen in forum Mori lathes
      Last Post: 03-11-2008, 10:06 AM
    5. anyone knows about Mazak Vertical Center?
      By kamran67 in forum General Metal Working Machines
      Last Post: 07-04-2005, 12:55 PM
