Hello,
I need to produce 10-20 small parts from Stainless steel per day, I need to do 3 cuts approximately 25mm long and 5mm wide and 5mm deep into the part.
Is the X4 can do this or I need a bigger mill?
Thanks!
All i work in is 316LVM and - 6AL-4V ELI I have never had any problems. You do need to mess around with the speeds and feeds. Infinite Body for my body jewelry and www.gregorycullum.com for my other stuff
