i like it!!! i just need a LIL more clearance on the z for a 30k rpm air spindle. whats pricing look like for full enclosure model with atc and if availible, CTS
New x6 linear machine present. compare old x6,it is update and we can see it is a new machine.
Table size 690×210mm
T slot QTY /width/center distance(mm) 3-16-63
Maximum load(KG) (kg) 100
X travel (mm) 330
Y travel (mm) 220
Z travel (mm) 320
Spindle nose to table (mm) 90-410
Spindle center to column (mm) 280
Spindle taper BT30
Max. spindle speed (Rpm)6000 or 10000(ATC model)
Main motor (kW)2.2
Servo optional.
X torque(N.M) 3.3
Y torque(N.M) 4.0
Z torque(N.M) 5.0
machine weight: 700kg
it is new and lead of this kind middel size cnc,
include industry spindle and package of ATC update.
later will have full encloser.
we use blance block to replace the gas spring.and update automatic oil to be standard parts.
syil all northamerica dealers have been in stocking.
the soonest delivery to US mainland will be at september.
the demo model also will present IMTS machine show in chicago.
Syil China.
Direction,Commitment,Follow through
I love it. I love the toolchanger. Single phase machine with 3 phase capability. Any videos of the toolchanger and any idea of the price yet?
it is can be update 24000rpm spindle.
we are now working on the x7 encloser with ATC.
when it done,will start on this model.
thank you
Is this machine syill 1 phase supply. Any idea of the machine price
the x6 linear standard resell price around 8350$
compare the tormach p1100,it is better much.
frist it is all 3 axis linear,use HIWIN brand.
then have blance block.
6000rpm spindle,and 700kG weight.
it is high class than tormach,but price just similar.
also,we still keep supplier x6 standard,compare smithy and Novakon,price still cheap..
Has a price for the plus version with side mount atc and BT 30 spindle been set as yet.
its all on the website...top of the line model with servos and the full monty (no enclosure) is roughly 20k...if you need more capability that what a base model will provide, id recommend getting a used "real" cnc
The cost I find is:
Syil X6 Plus $8995
4th Axis $1100
ATC $2000
= €10160
that would suit my needs without servos etc.
I would be interested to see the price of this New X6
Syil,
How many tools atc? Can we purchase atc only to be installed in our own machine (as per your ads on your website)? On previous video, atc is on the table different model from this one. My question is only this X6 use umbrella type atc. Other models X3-X5, use table mounted.
the new x6 linear standard and plus
we think syil dealers in US and canada will be resell at 9000$(standard) 9500$(plus) around.
we now just make MACH3,STEPER, package present,so will have Standard and plus model.
6000rpm spindle,3 axis linear include,and blance block,include the stands,and coolant.
about the ATC package model,later will present,
but frist coming it is ATC X7.we call new name at TC-70
will be include encloser,siemens controller,3 axis servo,spindle servo.
10000rpm spindle,coolant.
now just in inspection,and wait for present...
course it is need a lot of ducuments and inspect.so still need wait..
