Results 1 to 4 of 4
Thread: Spindle Revs Behaving badly on X4 plus
    Apr 2010
    New Zealand
    At any moment the revs can drop from programmed value to sometime 1/2 of programmed value, From 1-2 seconds before revs pick up again.
    it does not matter if M/C is in Manual or CNC mode.
    I have done a couple of jobs on the M/C and its Killing cutters.
    The spindle revs have no integrity.......
    Any ideas would be appreciated ?
    Registered neilw20's Avatar
    Jun 2007
    Are you running at maximum speed?
    If you are running at maximum speed, and it happens in manual and CNC mode, I have seen this.
    Reduce the maximum speed slightly.
    Whether the machine is reading the front panel pot or the CNC pwm, the a/d converter overflows if input signal is too close to rail voltage,
    causing the converted value to wrap to a small value.
    Software bug. Little chance of fixing the firmware that causes this.
    In CNC mode reduce your maximum speed slightly until it works reliably regardless of temperature and supply voltage.
    For manual mode, put a preset potentiometer, 1K would most likely be OK, in series with the clockwise end of the pot. This allows you to reduce the maximum output of the pot.
    I was not able to check the PCBs when I saw the fault, so I am not sure if any adjustments are possible.
    If you find a circuit, (in your wildest dreams), post it, and I will know for sure the easiest way to fix this.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Apr 2010
    New Zealand
    Hi Neilw20, thanks for your reply, sorry its taken a while to get back. I've been away for a few days.
    No the revs are not at full speed, the revs drop can occur from any rev setting.
    It may sometimes go for a good long while with no change and then it can return with a vengeance.
    Jun 2007
    Loose connection
    Search high and low for loose connections including earth screws, damaged wires, BAD CRIMPS, poorly fitting fuse clips, and examine the PCBs for suspect looking solder joints.
    Also wiggle the terminals on the front panel speed pot. They are also of a crimped nature.
    Hall sensor circuit board inside motor could also be a culprit.
    Does this happen at any temperature?
  1. Need Help!- Displaying real motor revs in EMC2
    By melee in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-03-2008, 04:57 AM
  2. Older Revs. of Mach3
    By ptig185 in forum Mach Software (ArtSoft software)
    Last Post: 05-01-2008, 04:17 AM
  3. Aluminum not behaving
    By carguy327 in forum General Metalwork Discussion
    Last Post: 09-21-2007, 09:45 PM
  4. Help - Motors Not Behaving
    By Firebird0095 in forum General Electronics Discussion
    Last Post: 11-15-2006, 10:01 AM
  5. stepper behaving awkwardly
    By shaiqbashir in forum Stepper Motors and Drives
    Last Post: 03-27-2006, 09:41 PM
