Results 1 to 8 of 8
Thread: 5 Axis Machining with Syil X5+
    Apr 2010
    I am looking to purchase a new Syil X5+. The advertised Specs state that the machine is "5th Axis ready". I would like do 5 axis (5 axis interpolation) machining by making a trunnion table with two (Syil) rotary tables. I am wanting to engrave/ mill over and around a sphere, using Bobcad to
    Has anybody had experience doing 5 axis machining on the Syil?
    Does the Mach Controller handle this successfully?
    I would appreciate hearing others experiences with this!
    Apr 2006
    China
    Quote Originally Posted by marklh View Post
    our interface board support 5 axis drivers.
    and mach3 support 6 axis run,so,it is not big problem.
    but we still not try this before,so,if you be frist customer to show us how it run that be fine.
    i`m very glad to expect to see those video.
    Direction,Commitment,Follow through
    Apr 2011
    Smile
    I would like to know if you completed your 5th axis set up - can you confirm the board connections for the driver from the 5th axis interface?
    Jul 2006
    Don't think bobcad does 5 axis. The geometry can get quite complex.
    If you do make some videos of it milling something You will probably have to take very very light cuts and keep all your programming in check for backlash, but it is a fun project.
    Here is one just moving around.
    http://www.youtube.com/watch?v=w0-tXDEvAqg]New CNC Trunnion Table can be 4th or 5th Axis made by HTS - YouTube
    And here the real deal
    "http://www.youtube.com/watch?v=gGRoeVow6fM"]Fräsen CNC Bearbeitungszentrum Alzmetall - YouTube
    Registered The Engine Guy's Avatar
    Jun 2008
    UK
    Ed from NY is correct, BobCAD will not produce the required toolpaths/code for 5th Axis machining, it doesn`t actually do full 4th Axis either, just simple 4th axis indexing and wrapping.
    To get a CadCAM software that will produce the required toolpaths and G code for full simultaneous 5 axis machining will cost quite a lot, maybe even as much or more than the machine itself
    Regards
    Rob
    Apr 2011
    Smile
    Thank's for that - I'm thinking Rhino will be a better solution. My next issue will be to get the trunnion built - there is not much Z depth to play with but i'm only going to be milling tiny stuff. I've got someone working on a Servo and driver, mounting this on the trunnion, I'll post the outcomes when I get there! The connections to the 5th Axis look like 5 volts from the specs on the Syil so I've just about got all my duckies lined up!
    Feb 2009
    Quote Originally Posted by The Engine Guy View Post
    You can get full 5-axis programming with SprutCAM for around $1000. I don't have it yet, but I only have 4 axes at the moment. Currently using BobCAD for up to 3-axis, and DeskProto for full 4th axis work.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Apr 2011
    I'll take a look at Sprutcam too, thanks.
    1. Power Drawbar/prototype ATC Syil China/ Syil Canada/ Syil North America
      By syil canada in forum Product and Manufacturer Announcements
      Last Post: 08-06-2010, 11:59 PM
    2. new retractable 56,000 Air spindle, Syil China / Syil Canada / Syil North America
      Last Post: 05-13-2010, 07:52 AM
    3. Syil X4+ 4th Axis
      By Martin Long in forum Syil Products
      Last Post: 08-03-2009, 01:55 AM
    4. Syil X4 and horizontal machining
      By cvafiadis in forum Syil Products
      Last Post: 11-13-2008, 08:06 PM
    5. Syil C6 Machining video - Map reader
      By PEU in forum Syil Products
      Last Post: 06-14-2008, 10:24 AM
