Results 1 to 8 of 8
Thread: Z AZIS
    Aug 2008
    united sates
    Z AZIS
    Do you think SYIL would sell me a bare bones z axis collum ? What do you think it would cost ?
    Registered Crevice Reamer's Avatar
    Mar 2008
    Quote Originally Posted by gabedrummin View Post
    What do you mean by barebones? What parts do you want exactly? Which mill, SX3 or X4?
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Aug 2008
    united sates
    A x-4 collum . Just the casting no screws no motor Just a raw casting . Thanks
    Sep 2005
    Indonesia
    Why not make it using linear rail and ballscrew? its easy.
    Mar 2008
    AFAIK, the X4 uses the same column as the Sieg X3/SX3. They are available from Grizzly for $98.75
    http://www.grizzly.com/products/g0463/parts
    CR
    Aug 2008
    united sates
    I do have one made with linear rails mounted to a 4 inch square allum. tubbung . But I would prefer to machine it from cast iron . The allum has to much flex for me . Got a quote for a solid piece of cast iron that would finish at 4x4x 32 delivered cost under 200.00 dollars but weights 178 pounds . A casting would be a little easier to move around with my bad back....I work in a tool and die shop with big cnc equipment so machining it is not a problem. Thanks
    Apr 2006
    China
    Quote Originally Posted by Crevice Reamer View Post
    CR
    if sx3,or x3,will be same as grizzly quote.but better confrim with sieg,
    i`m not sure how many edtion they use.
    but x4,it is different like x3 or sx3 column..
    you better confrim.then i may sent to you with shipment to my dealers.
    but it is sent from them to you also take a big cost of DHL or TNT..
    Direction,Commitment,Follow through
    Aug 2008
    united sates
    I have made a cnc mill that has 13 x 7 12 travles . It uses thk linear rails and ball scews . The machine is buildt on a 14 x 24 x 2.5 inch thick webed castiron surface plate my weak link is the z collum . It is made from allumium tubbing with a steel base there are 4 ..3/8 bolts that run from the steel base through the tubbing and attach at the top of the tubbing . My idea was to fill the tubbing with cement attach the tubbing top tighten the nuts to the top plate and
    it would be solid. I have not filled the tubbing yet and am experincing vibratiation .I dont know if the cement would eliminate the problem . So I am looking for a z axis collum that I could modify . Would you sell one from the x-5 ? The x-3 looks a little small . Thanks for your time .Thank you.
    1. Replies: 7
      Last Post: 01-21-2007, 08:56 PM
