Results 1 to 5 of 5
Thread: Ovals instead of circles??? X4
    Apr 2009
    Ok just decided to check how round my interpolated circles are. Openned a few round pockets from 1" to 3" via Mach3 wizards. Grabbed my trusty bore dial caliper. Bloody hell ! I have about 10 thou greater circle on Y than on X. X measured bang on for the radius but Y was greater.
    I checked backlash on Y against 1-2-3 block and an indicator in a spindle and coudnt see any perceptible backlash on Y.
    What may be the problem here?
    How can I fix it?
    Aug 2008
    united sates
    You might have to adjust your steps . I had a similar problem with a home built cnc . My x and y had differet pitch screws so screw resolution was critical . I used a 3 .0 inch gauge block and zeored off one end then indicated the other edge . Then adjusted the steps to make the move were it had to be .Then my cicrles were round . I did have to check ball screw preload , end block supports , shaft couppling , thrust bearings , ballnut carrier , everything connected to saddle screw and machine base abd table .If you tell the machine to move 3 inches in y dose it move three inches ?
    Apr 2009
    Quote Originally Posted by gabedrummin View Post
    I will check if it does accurate 3" on Y. In the meantime how one adjust the steps? Is that in Mach3?
    Aug 2008
    united sates
    I dont use mach 3 but all control software I have seen lets you set the steps per revalution My machine has 5mm ball screws my steppers do 200 steps for one full revultion. One full turn of my screw moves .19685 divided by 200 steps , makes each step=.000984. so one inch divided by .000984 is 1016.26013 steps to move one inch . So in my software I have 1016.260 set as my x axis resulotion.
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Hello,
    You should check the motor couplers on your X an Y axis. The set screw can work lose and add enough play into the system so that when the axis change direction(90º intervals) like on circles you end up having egg shapped or flat circles. My SX3 had come lose on the X axis and was cutting flats and after fixing that the circles were fine. I hope this helps.
    Regards,
    Regards,
    Wes
    1. TNC145 ovals?
      By Mike Woo in forum Bridgeport and Hardinge Mills
      Last Post: 11-05-2009, 10:40 PM
    2. Cost to cut ovals in full sheets of plywood
      By kengo in forum General Business Practices and Pricing
      Last Post: 07-02-2008, 09:25 PM
    3. Help!! Using Formulae to turn ovals with Mach3
      By rajiv.tctech in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-11-2008, 11:23 PM
    4. Ovals!
      By cxixer in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 01-31-2008, 07:32 PM
    5. Kcam not seeing ovals properly
      By monkamarm2000 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 06-30-2005, 03:40 PM
