Zero Tool on Z Axis
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Zero Tool on Z Axis
    Jun 2009
    South Africa
    Default Zero Tool on Z Axis
    I have read that someone has made a tool probe, and has configured Mach3 to auto zero the tool. I believe it can also be used as an edge finder.
    Can anyone offer any advice on how to do this?
    regards to all,
    Byron
    May 2006
    There are a range of ways this has been done. From the simple to fairly complex.
    For an example of a simple one have a look at this thread,
    http://www.cnczone.com/forums/showthread.php?t=36099
    And here is a demo of this and a couple of other ideas
    I use this on a router, engraver and mill.
    Greg
    "http://www.youtube.com/watch?v=Oc-9gTFj-y4"]YouTube - Laser Zero finder
    Jun 2009
    South Africa
    Thanks Greg,
    Where do I connect the probe on an SX3?
    Jul 2006
    I'm very interested in this as well. Here is a pic of the board from the manual and the board I have. Is it one of the 5 empty connectors labeled pin1-pin5? I searched for a manual on this board but did not find anything. All we have is that the aux are pins 1 (OUT) and 7 (OUT) on the parallel (says so on the Sieg manual). I think one might already be in use if you have the coolant option (?)
    Are these just open/close contacts and the only thing we need to do is to put something that either opens or closes the circuit when the position is reached and the corresponding hi/lo will be relayed on the parallel port or is it more complicated?
    [Edit]
    There is also a "Digitizing Probe" at pin 11 (IN), but there is no other mention of it in the Sieg Manual.
    Attached Thumbnails Attached Thumbnails Zero Tool on Z Axis-manual-pcb-gif   Zero Tool on Z Axis-pcb-jpg
    May 2006
    Use pin 11. The one beside the estop.
    Greg
    Jul 2006
    Quote Originally Posted by Greolt View Post
    Greg
    Hi Greg, on the PCB the socket next to the e-stop is marked "pin 5" (pin 6 is the e-stop and pin 10 is the A ref. The pin 11 mentioned in my original post is on the parallel port. Do you believe that pin 5 on the board (the one next to the e-stop) maps to pin 11 on the parallel port? Sorry, just want to make sure
  7. #7
    Jun 2009
    South Africa
    These plugs have three pins. Which two terminals are used?
    One wire would go to the touch pad (pcb or similar), where does the other wire go to?
  8. #8
    May 2006
    This is all the info I have.
    Make sure it is the same version and you should be right.
    Greg
    Attached Files Attached Files
  9. #9
    Jun 2009
    South Africa
    Thanks Greg,
    Ill take a look now.
    byron
  10. #10
    Jun 2009
    South Africa
    ......PROBLEM!!!
    I have a different board. There is no plug for "Tool Adjuster Interface"
    Can I use the A-Axis Limit plug?
  11. #11
    Jun 2009
    South Africa
    This is what it looks like - See attached.
    Attached Thumbnails Attached Thumbnails Zero Tool on Z Axis-dsc03451-jpg
  12. #12
    May 2006
    Those labels are just what the BoB manufacturer put on them.
    Mach does not care what you use inputs for. You have five on the first LPT, 10 11 12 13 and 15
    So by all means use that input if it is spare.
    Greg
  13. #13
    Jun 2009
    South Africa
    Thanks Greg,
    I'll give it a try in the morning.
    In Mach3, under ports and pins - inputs, I am setting up the "probe" right?
  14. #14
    May 2006
    That's right.
    And on the diagnostics page the LED you want to look at is called Digitise.
    Greg
  15. #15
    Jun 2009
    South Africa
    Thanks Greg,
    I'll give it a try tomorrow morning.
    Seems simple enough ..... "famous last words!"
    Best regards,
    Byron
  16. #16
    Jun 2009
    South Africa
    I cannot believe how easy that was!
    Thanks Greg!
    It should have been done a long time ago.
    If I wanted to create my own screen In Mach3, How do I go about doing this?
    I would like to have more control of the spindle, In particular, the overrides.
  17. #17
    May 2006
    Mach has a screen designer called Screen4. It is often referred to as Scream4.
    It is a bit flakey but does work. Lots of screens have been done with this.
    To get away from most of it's bugs, edit on a larger screen resolution. So that scrolling is not necessary.
    http://www.machsupport.com/downloads/Screen4.zip
    The other option is the new kid on the block called MachScreen.
    http://www.machsupport.com/forum/ind...c,11618.0.html
    Greg
  18. #18
    Jun 2009
    South Africa
    I'll give them a try later on. I have downloaded both of them.
    Once again Greg, Thanks.
  19. #19
    Jul 2006
    What is the name of the connector for those pins... the ones that plug in the 3 wires for the sensors? I need to get one, but I need to search by name.
    Thanks!
  20. #20
    May 2006
    Quote Originally Posted by Ed from NY View Post
    Thanks!
    I also asked that question a long time ago. See here for post,
    http://www.cnczone.com/forums/showthread.php?t=23773
    Greg
Zero Tool on Z Axis
Zero Tool on Z Axis
