Zero Tool on Z Axis - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: Zero Tool on Z Axis
  1. #21
    Jul 2006
    Hi Greg,
    Inspired by your solution I just did the same... found a computer fan connector and sanded it down...
    Oh well
  2. #22
    Jul 2006
    Success!
    The electric is connected and it shows in the digitize signal in Mach3!!!
    Not sure if you remember, Greg, how alien and challenging simple things like this were for you when you first got started, well they certainly have been for me.
    Thank you!
    [Edit]
    One thing that was not that obvious to me is that you already have ground on the entire machine, so really you only have to bring out the signal pin (the one in the middle) and have it hooked up to your zeroing widget. The tool will be the ground because it is already linked to the machine.
    The other thing is that the table of the mill and many of your workpieces will be metal, so your zeroing widget can not conduct electricity in the spots where it will touch the workpiece. Otherwise the machine will think it is already zeroed before it starts.
  3. #23
    Feb 2008
    Hi guys
    I have also tried but with not as much success. If anyone can help that would be great.
    I am getting an error message that says, Z- Plate is grounded or check the connection and try again. When I put my touch plate to ground the LED light goes out on the screen and the Z probe begins to work. It seems to me it is working in reverse. Could some one please tell me what I have done wrong.
    Thanks Greg
  4. #24
    May 2006
    Sounds like you need to reverse the active setting in "ports and pins"
    Set the probe input to "active low"
    Greg
  5. #25
    Jun 2009
    South Africa
    Smile
    That should do the trick.
  6. #26
    Feb 2008
    Hi Greg
    Thanks for your quick reply. I have changed the setting in ports and pins and it is working great. Thanks for all the info I could not have done this myself.
    Thanks greg
  7. #27
    May 2006
    No worries mate.
    Always happy to help a fellow Aussie.
    Greg
  8. #28
    Jun 2009
    South Africa
    He has also been known to help a South African out from time to time!
  9. #29
    May 2006
    Only if they don't beat us at cricket.
    Feeling a bit sorry for ourselves at the moment.
  10. #30
    Jun 2009
    South Africa
    Wink
    Maybe I should have kept my mouth shut!
    Finding help now may become a problem.
  11. #31
    May 2006
    Aug 2010
    Does anyone have experience with this board. I can't get to an available input for a Z plate as well!
    http://www.cnczone.com/forums/genera...ate_input.html
  13. #33
    Jul 2015
    Default Re: Zero Tool on Z Axis
    i have a problem like that i have 4 axis toshiba 6560 and it just have pins for limit switches and estop x,y,z,estop ,nc,gnd pin header and there is no pin 15 in the header
    this is my board
    Zero Tool on Z Axis-tb6560-4axiscnccontroller-jpg
    should i solder a wire to lpt pin 15 ?
Zero Tool on Z Axis
Zero Tool on Z Axis
