Problem Y axis squeaks in one direction
Results 1 to 3 of 3
Thread: Y axis squeaks in one direction
    Jul 2008
    Default Y axis squeaks in one direction
    I have a Summit VS242B CNC knee mill. Today, when I started it up, there is a noticeable "squeak" only when I move the Y axis towards me. It squeaks when I move the Y axis manually also. There does not seem to be any drag on the axis. Any suggestions?
    Member awerby's Avatar
    Apr 2004
    Default Re: Y axis squeaks in one direction
    Check the coupler that connects the Y axis motor to the screw; it sounds like it might be loose.
    Jul 2008
    Thanks for the info Andrew. I will check it out
