I found the problem. The coupler from the motor to the ball screw was loose. At least it was a simple fix.
I was running a program on my Syil X3 CNC mill with Mach3 software and everything was working well. I was cutting a deep pocket and the Z axis suddenly quit moving. Both X and Y work. When I home all, the Z axis DRO counts down, but the axis does not move. I can home X and Y with no problem. I noticed when I tried to move the Z axis a while later, there was an audible noise when I pressed page up and page down, so it appears the motor is still getting electricity, but the head is not moving. I may have to remove the back shield and see if the motor is trying to turn. Do you guys have any troubleshooting tricks I should try?
- Syil X5 Linear CNC Mill 1.5hp with stand and 4th axis
- Does Syil offer 5 axis CNC mill?
- Power Drawbar/prototype ATC Syil China/ Syil Canada/ Syil North America
- new retractable 56,000 Air spindle, Syil China / Syil Canada / Syil North America
- I have a problem with my Taig CNC Mill.. x-axis mechanical movement
Coupler loose? Mine actually broke years ago so I made a new one.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
