Discuss Swiss Lathes here!
There are currently 1 users browsing this forum. (0 members & 1 guests)
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
It has done it with 3/32 ballnose as well so it may work sometimes to change the diameter but not...
I have not used the T nuts in a long time as they are covered. The size was the 1/4" - 20 bolt...
Vancouver, British Columbia Canada
Thankfully my problem was solved. Turnd out to be a blown chip on the control board of the...
If you are stuck for the 10, I have the 15T which is pretty close. Al.
untrust worthy code output
