Hello,
I'm a new poster and not sure if I'm in the correct forum but I have a fault on a Tsugami BS26CE-V machine. I'm not familiar with these machines but as the factory electrician the machine operators have asked me if I can have a look at the problem.
When running, the machine will stop and show the error code "1010 coolant alarm". The machine will then no longer run and can only be reset by switching the machine off and back on. There is no obvious problem with the coolant pump.
Can anyone help? Thanks.
