Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Super Tech Controllers, SuperCam & SuperCamXp
Super Tech Controllers, SuperCam & SuperCamXp CAD combined with MachineControl
Old 12-03-2007, 08:21 PM
heliboy is on a distinguished road
Incremental axis advancement
Hi Guys,
I have a problem with my Taig mill with Mach 3 and Dolphin Cad/Cam. When I execute a code on the mill it will sometimes run x,y and z at a constant speed but I can load the same program later in the day and it will run the axis in incremental or stop start. Why is this? Am I doing something wrong in the drawing or what. Need help.
Old 12-07-2007, 02:20 PM
Dennis Bohlke's Avatar
Dennis Bohlke is on a distinguished road
You may have a program running in background like updating the hard drive file index.
Check the Task Manager when the machine is not running correctly, for programs taking CPU time.
Mach3 requires a pristine system configuration.
With the USB CamPod and SuperCamXp the machine movement will not be affected by Windows background system calls.
Dennis
http://www.super-tech.com
Old 12-07-2007, 07:51 PM
Thank you very much for the info. I will take a look at the task manager.
Dell
Switch to Incremental moldmker BobCad-Cam 3 10-06-2007 10:43 AM
Absolute or Incremental mikede Haas Mills 1 02-03-2007 06:02 PM
benefits of incremental? paelscrit G-Code Programing 15 01-27-2006 10:27 PM
Incremental encoder mihan General Electronics Discussion 3 09-10-2005 05:21 PM
Absolute and Incremental ACME G-Code Programing 3 09-04-2004 06:45 PM
