Results 1 to 6 of 6
Thread: Seperate forum for Epoxy Granite
    Jun 2005
    Exclamation Seperate forum for Epoxy Granite
    Hello,
    The Epoxy Granite Thread is maturing. Other's are starting threads in other forums based on what is being taught/learned/discovered/experienced in the EG thread.
    My concern is with the increase of EG projects, the information will start to become fragmented in different forums and thus difficult keep up with new emerging threads.
    Some suggested names:
    Epoxy Granite
    Polymer Composites
    Polymer based Machine Construction
    Or simply put it up for a vote.
    Something along that style.
    Comments?
    Thanks,
    Jack
    Feb 2009
    Agreed! I would like to read and learn, but the single thread is HUGE and fragmented, and as new threads start in scattered areas it will become very difficult to keep up with it. A single forum to allow diverse discussion on a single theme is the point of the board, right? Sounds like a perfect argument for it...
    Dec 2006
    I believe it's the best way to go!
    I suggest "Epoxy Granite" for the forum name.
    Best regards
    Bruno
    Apr 2007
    india
    Its time for Moderators to decide & act, i think further discussion on this is not required.
    Site Owner CNCadmin's Avatar
    Mar 2003
    Is this what you guys want? -http://www.cnczone.com/forums/forumdisplay.php?f=481
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Jun 2005
    Quote Originally Posted by CNCadmin View Post
    Thanks Paul,
    I was hoping for a forum off the root for better visibility.
    "CNCzone.com-The Largest Machinist Community on the net! > Epoxy Granite"
    EG is more of an engineering process that give one the ability to not only build machines, but parts such as linear bearings, gears, etc. Plus refitting existing machine for better vibration damping.
    Heck I've experimented making Lego's with 100% Zeospheres and 10% epoxy! I just need a better molding process. But I digress.
    Comments?
    Best Regards,
    Jack
    1. 8020 Extrusions with Epoxy Granite filler?
      By reiyuki in forum 80/20 TSLOTS and other Aluminum Framing Systems
      Last Post: 02-12-2010, 03:10 AM
    2. epoxy-granite in the mini lathe bed?
      By regcabdak1 in forum Mini Lathe
      Last Post: 02-25-2009, 06:18 PM
    3. New Machine Build- Epoxy/Granite Gantry Router
      By johnohara in forum Open Source CNC Machine Designs
      Last Post: 09-22-2008, 09:43 PM
    4. Epoxy-Granite CNC Lathe Design (and Build)
      By romihs in forum Vertical Mill, Lathe Project Log
      Last Post: 03-29-2008, 07:36 PM
    5. Epoxy/granite machine concept
      By Gizmot in forum Vertical Mill, Lathe Project Log
      Last Post: 02-28-2008, 03:46 PM
